300 LX Pull Pull
FL
Hey Tom... This may sound like a dumb question but when I set up pull pull on the rudder on other planes I cross the wires to get a good alignment out the exit holes. Last night when setting up the 300 with pull pull I noticed that the wires want to rub on the back of the exit holes when the wires were crossed.... So should they be crossed or not?
John
John
ON, CANADA
I noticed this also last night, so I tried a straight configuration. They rubbed still. I'm using a 3" arm on the servo. To fix this I added some ny-rod to the exit hole. This should help prevent the cable from chaffing. Jared
CA
I had the same problem on my Edge 540T. If you look closely down the inside
of the fuselage, you might see the pull-pull cable rubbing on a former just ahead
of the exit hole. It was tricky, but I marked on the former with a pen where the
wire was rubbing and then used a dremel with the round drum sander to create
a half cirle cut out on the former where the wire rubbed. Problem solved.
Gerald
