Flying Without The Engine Cowl
My Feedback: (17)
I finishing up my 84" WH Edge with a G62 and hope to maiden it this weekend or early next week. I want to wait for a Bisson side mount muffler which won't be available until early August, so I'm planning to use the stock Zenoah muffler and fly without the cowl. I don't think there is a problem doing this but just want to make sure. Comments?
The reason for the side mount Bisson is I've heard it is a tad quieter than the wrap around, provides a little more power, and is 3 oz lighter. If someone has another suggestion, I'm open.
Chuck
Chuck
NOT A PROBLEM AT ALL AS LONG AS YOUR CG IS CORRECT I FLEW MINE WITHOUT A COWEL AS IT WAS THE ONLY WAY TO TEST AND TUNE ENGINE AND I DID NOT WANT TO TAKE MUFFLER SPINNER PROP AND COWEL 5 TIMES IN AN HOUR IT FLEW FINE .
Having used both I think the wrap around is quieter, but the side mount has a couple of more rpm. All trade offs one way or the other based upon what you can deal with. I've flown all my Wild Hares with and without a cowl without issue. The open fronts have been closed and open without any noted differences. Flying without a cowl does make a significant difference in the way the plane appears on approach and alters your judgement a little. Sure makes it easy to access the needles, tho.
