WildHare R/C Support Disscuss WildHare RC products in this forum. Please note, answers may be provided by Tom Fawcett (owner of WildHare RC) or by the general membership.
Smaller Bunnies
Old 09-03-2007 | 09:21 PM
airborneSGT's Avatar
My Feedback: (15)
Default Smaller Bunnies
Tom,
Just wondering what the status of the smaller bunnies is? I recall a 25% Edge and Extra 260 was in the mix at some point. Only mention something as I have a Saito 180 and Moki 2.10 in need of a home!
Old 09-03-2007 | 11:34 PM
rctom's Avatar
Default RE: Smaller Bunnies
They are almost here, will be in the next container at the end of this month. An Edge version and an Extra 260 version.
They are extremely light, I don't know if either of your engines would be too much power. I expect them to weigh about 9 lbs witha 2 pound engine like a Thunder Tiger 1.20.
More soon.
TF
Old 09-04-2007 | 02:19 PM
SunShyne's Avatar
My Feedback: (68)
Tom
if you ever get a CAP lemme know, ill pre-pay for one
Might have to get an Extra for the meanwhile
Old 09-08-2007 | 09:28 AM
My Feedback: (19)
Tom , any pictures of the smaller planes ? Projected price ?
Thanks , Dorin Luck
Old 09-08-2007 | 12:45 PM
rctom's Avatar
Here are photos of the new Baby Edge and the 73"Extra 260. They should be here in a few weeks, price will be around $300.
I'm recommending the OS 1.20 AX as an ideal engine for these planes, but I will also have a recommended electric power setup.
TF
ID:	758978   Click image for larger version
ID:	758979   Click image for larger version
ID:	758980   Click image for larger version
ID:	758981   Click image for larger version
ID:	758982   Click image for larger version
Old 09-08-2007 | 03:59 PM
OOOOOOOOO ME LIKE.
Old 09-08-2007 | 11:21 PM
SunShyne's Avatar
My Feedback: (68)
nice pics, they look good[sm=thumbs_up.gif]
Old 09-09-2007 | 08:10 AM
My Feedback: (134)
Will these be the only color schemes?
Old 09-09-2007 | 11:59 AM
rctom's Avatar
ORIGINAL: sailing1
Yes, for now.
TF
Old 09-09-2007 | 04:14 PM
Redneck Shaun's Avatar
Tom what would you recommend?
Shaun
Old 09-09-2007 | 11:41 PM
rctom's Avatar
This is one approach thatwas used onone of the prototypes.
For sport flying and some 3D maneuvers but no hovering use the AXI 4130/16 on 6S 4000-5000mAh and a Castle Phoenix 80 controller with an APCE 16X8 or 16X10 prop. This should be a 1000-1200W setup. This is the upper limit of this motor so be careful.
For ballistic performance (it has not been flown it this way but this info comes from a very experienced pilot) try an AXI 5320/24 on 8S 3000-4000mAh and a Castle 45HV or 85HV and an APCE 20X8 or 20X10 prop. This should produce ~1700W and should be considered the upper limit of the airframe. It should weigh ~9-10lb and getting CG should be no problem.
Both will also need an external BEC or flight battery to supply power to the radio gear.
MPI has some suggested higher voltage combos that ought to work well also.
TF
Old 09-10-2007 | 05:19 PM
Tom, Are you taking any pre-orders?
Old 09-10-2007 | 10:15 PM
rctom's Avatar
ORIGINAL: Han2007
Yes. Just call me at 817-430-0107.
TF
SunShyne's Avatar
My Feedback: (68)
Tom
what glow motors did you fly these with? Any you use that provided good 3D capability?
Old 09-10-2007 | 11:04 PM
My Feedback: (15)
Maybe I should buy one and do a review on it. Probably will be over kill with what I have planned for power. The 260 looks exactly like the larger 260 I have!
Old 09-11-2007 | 09:34 AM
rctom's Avatar
ORIGINAL: DiabloKid
Tom
I tested it with an OS 1.60. It was insanely overpowered. It would go straight up at a higher speed than most planes will go horizontal. There is no need for that much power.
An OS 1.20 AX or Thunder Tiger 1.20 Pro will be way more than enough to rocket out of a hover, even a good .91 would probably do it.
TF
Old 09-12-2007 | 07:52 PM
My Feedback: (30)
Tom,
How about a 3w-24 in one of these planes? Too heavy or too powerful? What adaptations would you have to make to use a 3w-24? I have a couple laying around which are begging for a home. They are left over from a past project.
Thanks Elson
Old 09-12-2007 | 10:09 PM
rctom's Avatar
3w24 would probably be excellent.
Old 09-15-2007 | 11:42 PM
SunShyne's Avatar
My Feedback: (68)
ORIGINAL: rctom
ORIGINAL: DiabloKid
Tom
TF
all I have is the 1.60 laying around! lol
might have to spend the change for the OS 120 2 stroker..
Old 09-16-2007 | 09:40 AM
rctom's Avatar
Use the 1.60, but you will never need full power.
TF
Old 09-16-2007 | 03:41 PM
mstroh3961's Avatar
anyone with a loose YS 1.10 should be real happy too!
Old 09-16-2007 | 05:08 PM
How much do you expect these to go for Tom. I think I'm going to have to hold off on the 100cc.
rctom's Avatar
Yeah, a YS 1.10 ought to be an excellent match.
TF
Old 09-16-2007 | 08:19 PM
My Feedback: (134)
I believe Tom said around $300 in a previous post on this thread.
Old 09-19-2007 | 12:09 PM
My Feedback: (8)
ORIGINAL: mstroh3961
Hmm. I happen to have a loose YS 1.10...
