XHeli.com Support Forum If you have a question, problem or concern about your product from xheli.com, please use this forum to get answers to your questions.
EXI 250
Old 06-06-2010 | 08:59 AM
RC RedHots's Avatar
Default EXI 250
<p style="margin-bottom: 0in"><font size="4"><font size="2" style="font-size: 11pt"></font></font></p><p style="margin-bottom: 0in"><font size="2" style="font-size: 9pt">Andy or Anyone</font></p><p style="margin-bottom: 0in"><font size="2" style="font-size: 9pt">Can you give me the run down on the EXI 250 (things needed to finish)</font></p><p style="margin-bottom: 0in"><font size="2" style="font-size: 9pt">A list other then the radio system</font></p><p style="margin-bottom: 0in"><font size="2" style="font-size: 9pt">Servos size or number part number (standard and digital)</font></p><p style="margin-bottom: 0in"><font size="2" style="font-size: 9pt">Tail Servo (digital)</font></p><p style="margin-bottom: 0in"><font size="2" style="font-size: 9pt">Gyro </font></p><p style="margin-bottom: 0in"><font size="2" style="font-size: 9pt">Motor</font></p><p style="margin-bottom: 0in"><font size="2" style="font-size: 9pt">Anything else I may need.</font></p><p style="margin-bottom: 0in"><font size="2" style="font-size: 9pt">Thanks RCREDHOTS</font></p>
Old 06-11-2010 | 04:47 PM
Default RE: EXI 250
now the exi 250 uses the same electronics as the trex 250 so you can see what the pro ppl have on their trex 250.
you'll need micro servo 3 for the cyclic and one for the tail. you can use our gy48V and that will do it. for motor you can get them here: http://www.xheli.com/200sibrmo.html
you'll need 11.1v 800mah 30C lipo for the heli.
Andy
Old 06-11-2010 | 07:54 PM
RC RedHots's Avatar
Default RE: EXI 250
Do I have a 2nd or 3rdchoice on the motor? one place I found said a 34 KV and one more was higher.
And what size is the drive pinion (is it 2 mm)
It would be better if the page listed a list of items / parts to finish! in a little more detail!
If you want me to buy from Xheli toss me a bone!
How about the D213F servos?
ORIGINAL: yadac123
Andy
Old 06-18-2010 | 06:54 PM
Default RE: EXI 250
ok motor: http://www.hobbypartz.com/250class-5150kv.html
servos: http://www.hobbypartz.com/9gexidimeges.html
gyro: http://www.hobbypartz.com/60p-dy-1017.html
ESC: http://www.hobbypartz.com/topro40aelbr.html
the shaft size on this motor is 2.3 and the pinon gear that came with the kit will work on this motor.
Andy
