YS 91AC problem
My Feedback: (198)
Dave,
I have a 91 that has been sitting on the shelf for years. I finally mounted it and fired it up this weekend. I can not get the motor to tune.
No matter what I do it seems to load up, it also is spitting alot of fuel out of the venturi. I can get it to run full throttle but it takes forever to slowly get there. At 2.5 turns open I can even make the engine run without the glow ignitor. It is running at about 1 turn on the high needle.
Once I get it running at WOT and go back to idle, then let it idle for a five seconds and then I go back to full throttle it take 15 seconds to get back to a high rpm.
If I go from full throttle back to idle then right back to full it transitions fine.
