YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Supercharging
Old 05-05-2005 | 12:08 AM
My Feedback: (17)
Default Supercharging
Does the YS engines, particularly the 110, actually supercharge the air into the engine? If yes, about what percentage above ambient air pressure does it introduce into the carb? If this is the case wouldn't these engines lose less HP at higher elevations than a naturally aspirated engine? Just wondering.
Barry
Old 05-05-2005 | 06:51 AM
Hobbsy's Avatar
My Feedback: (102)
Default RE: Supercharging
Mistake, Post instead of PM.
Old 05-05-2005 | 11:16 AM
They are not truly supercharged. They use the downstroke of the piston to push mixture into the cylinder through the use of a double sided disc valve in the backplate.
Sort of a combination 2 stroke/4stroke set up. It works very well.
