YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 53, problem!
Old 10-09-2002 | 07:57 PM
Default YS 53, problem!
Hi,
I have a YS 53 that runs really bad between idle and mid throttle. It seems like it is running real rich, I can see a large fuel spray going into the carburator at this setting. The engine has very good compression and all new regulator parts. This engine has never preformed good since I bought it. What can I do to get this engine to run correctly? Its going to become a paper weight soon.
Keith
WOW
Old 10-09-2002 | 08:07 PM
Have you tried adjusting the regulator?
Does this engine have the adjustable airbleed?
Let me know.
Dave
Old 10-10-2002 | 09:28 PM
Hi Dave,
I did try to adjust the regulator but it does not clear up the problem in most cases it made it worse. The carburetor does have the air bleed and its adjustments does not seam to make much differance. To get the engine to run at high rpm the main neddle is set at about 1 1/4 turns out. I did set the regulator at the position stated by the manual, that setting did not work either.
Keith
Old 10-10-2002 | 10:50 PM
The engine needs to come and see us. Please provide a description of the problem and your daytime phone should we need to reach you.
Shipping address:
YS Service
1295 Industrial Court
Gardnerville, NV 89410
Phone 775-782-4562
Thank You,
Dave
Old 10-11-2002 | 03:06 AM
Thanks Dave, I will send the engine to the service department.
Keith
Old 10-13-2002 | 02:56 AM
filtr-RCU's Avatar
Aracobra
Did you adjust the low end needle. This will cause the problem that you are stating. The low end needle turns the opposite direction than the high end needle. I had the same problem with one of my 53 engines with this problem.
Ron
