YS Engines Support Direct support from YS Performance Engines by Dave Shadel
regulator vs idling adjusting for YS61
Old 10-09-2006 | 09:10 PM
Default regulator vs idling adjusting for YS61
Hi Dave,
I had trouble fine tune my 61AR idling spped after replace with a new diaphram.
I had the regulator adjust to a position that both high ( with high needle valve adjusted ) and idling seems to be fine while the plane is siting on the ground. However, when I raise up the nose of the plane while idling, the rpm drop right away and engine stops. I asume it is too lean and strat screwing out the regulator screw (1/8 turn each time). The problem seems to improve slowly. Therefore, I keep screw out the regulator to a point that I almost believe it can be too rick. However, I can only keep the engine idling for less than 6 seconds at the nose up position ( vertical).
Do I do it right? What should I do?
Thanks very much
Mike
Old 10-10-2006 | 10:35 AM
Default RE: regulator vs idling adjusting for YS61
Plug? Fuel?
Old 10-10-2006 | 03:12 PM
plug: Temporary using tower hobbies tower plug.
Fuel: Cool power 20% heli
Mike
Old 10-10-2006 | 07:23 PM
Try an OS #8 and see if it fixes the problem.
Old 10-11-2006 | 03:29 PM
I will go get the plug and let you know the results.
Mike
Old 10-15-2006 | 07:50 PM
I test the engine today with the new OS #8 plug. It helps starting the engine, but the problem is still the same.
I endup almost screw out the whole regulator. I worry that there is a pressure (air) leak in the regulator. As long as I have more than 1/4 throttle, the iddling won't stop at 90 degree position.
I check the O-ring, it seems still ok. I am thinking getting a new one,but I am not sure if that is the cause.
The engine is old and the O-ring is old.
Or,I was wrong that I shouldl lean the regulator ?
Appreciate your help!
Mike
Old 10-16-2006 | 09:04 AM
I would start by replacing all the gaskets, o-rings and regulator parts. Then completely change all the lines from the tank to the engine. Make sure the check valve is working OK.
Old 10-24-2006 | 07:43 PM
Problem solved. Replace the rubber plunger which loose the flexibility, both gaskets and one o-ring for the the needle valve .
It is running great now.
Thanks for the help.
Mike
Old 10-24-2006 | 08:57 PM
Great!
Good Flying!
