YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS160DZ Cutting Out
Old 10-21-2007 | 03:43 PM
Default YS160DZ Cutting Out
Hi
I am having difficulty with my new 160DZ. It is installed inverted in an Extreme Flight Yak54, I am using fuel with 20% nitro and 20% oil and a 18x6w APC blade.
The tank has three lines, one to the pump (and using the felt clunk), one for filling via a fuel dot and a vent line going straight to atmosphere without any check valves.
The engine starts easily but will cut out abrubtly and I can see no reason why. At half throttle it will run for 1 minute and then stop - no hesitation, it just stops. This behaviour is repeatable.
The plug (an OS 4 stroke plug) looks fine. I have tried altering the HS needle from 1.5 to 3 turns with no effect.
Can anyone suggest what may be at fault?
Old 10-21-2007 | 04:29 PM
Default RE: YS160DZ Cutting Out
The pump may be a little too rich. Dial the pump Out CCW about 1/4 turn and see what happens.
What you are likely seeing is the richness is semi flooding the engine while its running. the DZ engines put raw fuel injected in the head...This will put the glow plug out.
Just because the plug looks OK or just because it glows doesn't mean its a good plug.
A glow plug is not like a spark plug....the plug coil is coated to provided the catalyst to aid in the combustion. This coating can burn off or get a hot spot in it...Plug coil will look OK but it will not be working properly in the combustion. Yes you can eye ball it and see if its bad, but in some cases it could have a slight flaw in it from a small hot spot in a critical spot on the coil. This will keep the plug from making the right heat and having the proper chemical reaction with the fuel.
In your case I think its just a little rich on the pump so lean it out CCW, and then reset your top end....Get the engine to operating temp slowly and then let it run at 1/2 power and see what is going on.
Usually the pump will have more to do with lower power settings as far as mixture in concerned....The HS will have an effect but its pretty minimal when the engine is below 1/2 power.
Troy Newman
Team YS
