ys 45 basic question
In the ys 45 there are two fittings from the crankcase one near the front damper and the other next to it nearest toward backplate of the engine.
which of this two is connected to the fuel clunk, and which of this is connected to the check valve and to the pressure return.
Thank you in advance.
RE: ys 45 basic question
I believe the front one is fuel and the rear one is pressure. I'll have to double check I don't have a 2 stroke manual sheet around.
It has been a long long time since I worked with those engines.
Troy Newman
Team YS
Troy Newman
Team YS
IA
Here's the spec sheet Troy!
Should look something like this. The example shown is the side exhaust version, yours might be the rear exhaust version, but the same connections should hold true.
