YS Engines Support Direct support from YS Performance Engines by Dave Shadel
YS 63 break in procedure question
Old 04-03-2003 | 07:44 PM
Default YS 63 break in procedure question
Hi Dave-
Just fired up my 63 for the first time yesterday and I had some questions. How hot should I allow the engine to get? I ran it pretty rich, rich enough so that I could touch the valve cover without needing to immediately pull my hand away. Secondly, how rich is rich? The instructions just say "a rich setting." I was running it at 8800 RPM with a MA 13x6. YS 20/20 Wildcat fuel with an OS F plug. Did my break in actually do anything, or should I do it again at higher RPM and higher temperature? Then lastly, do you recommend running it at full throttle for most of the 20 requisite minutes? The instructions don't make a mention of this either.
Thank you!
Reid
Old 04-07-2003 | 06:02 PM
Dave?
Old 04-08-2003 | 09:10 AM
squareloop's Avatar
Hope this helps. I just got this engine too and found this thread buried in all the other ys 63 threads.
http://www.rcuniverse.com/showthread...35&forumid=156]
