YS Engines Support Direct support from YS Performance Engines by Dave Shadel
Props
Old 12-04-2007 | 01:10 PM
Default Props
Hi,
Do you have any idea how the Mejzlik composite props work on the 160 , for pattern application?
I was thinking about trying one of them; 3-blade 16x11. I know some brands run different than others, but what do you think about this size ?
Kjell Olav
Old 12-04-2007 | 02:40 PM
Default RE: Props
never run it myself.
I have run the 16.5-10 3blade Bolly on a 140DZ years ago. It was awesome in the performance category and I would have used it but........
The noise was 100db with the engine turning it at 7900rpm. I had to dial the rpms back to 7200 before the noise was at the 94db limit on pavement. At this rpm the performance was not good at all.
Not sure on the Mejzlik offering but I do know that the 18-10 they make is good if you keep the rpms down again it gets too noisy. This is why many of the top pilots have gone back to the 16 and 17 inch blades or the 4 blade props.
Smaller diamters are quieter for the given rpms....if you runa 17" prop at 8000rpm it will be on the limit for FAI noise. So many have tried the 16.5-13W and even the 17-12W props for noise....
Troy
Old 12-06-2007 | 01:54 AM
Default RE: Props
... I like the props to be on the "light-driven side" .... In my experience ,this give the engine -performance-envelope larger tolerance ... less critical about conditions ,adjustments, performance etc...
... the only thing is the noise ...
I believe the 16x11 3-bld is a "light-one", and the only way to find out is to try it.
Kjell Olav
Old 12-06-2007 | 01:42 PM
Default RE: Props
by all means give it a try. I have thought about that prop and it might be good.
I don't really like the 3 and 4 blades as they don't spool up as well. Its a different kind of flying.
I have spent lots of time with the 4 blade 15.5-12.5 and I really liked some aspects of it and other I didn't.
This could be a good selection just don't know.
Troy Newman
Team YS
