YS heli engines
CO
Can the YS 2 stroke heli engines be used for airplanes? Will a prop thrust driver for a .61 airplane engine fit on the larger(.91) heli engine, or is there a difference in crankshaft diameter, or some other mismatch? I'm thinking of using the .91 and a speed prop in a Patriot XL. I want the benefits of large displacement and a regulated fuel system in a proven package. Thanks!
The problem is the shafts are much shorter length. You may have trouble doing it.
I have no experience with doing this and don't recommend it.
Troy Newman
Team YS
Troy Newman
Team YS
Hi,
I have converted the YS91st to an aero engine, works very well. Here are the YS spares that you require.
Drive washer retainer - YS spare part no. F9324
Drive washer - YS spare part no. F9323
Tru Turn 8x1.0mm short shaft double jam kit - Tru Turn spare part no.TT-0813-A
Hatori manifold and pipes fit ok.
Hope this helps.
Regards,
Sydc.
Hope this helps.
Regards,
Sydc.
Hi,
I used an APC 13x7 which gave about 11,800 rpm with pipe on YS 20/20. Exceptional power with this setup, fitted in a Dave Smith Excelsior 177.
CO
That definitely sounds like the way to go. Those numbers are real healthy for a .91 and leads me to think a more square prop like a 12x10 also might be worthy of consideration as long as it doesn't bog things down enough to cause the engine to drop off the pipe. I suspect the engine will work just fine as it unloads in the air. This is going to be a great combination and plenty fast. I bet the rate of fuel consumption will end up leading me to use multiple tanks. I love it when a project starts provoking my adrenal glands even before construction starts![sm=bananahead.gif]
