DZ idle problem
My Feedback: (198)
I can not seem to make my engine idle anywhere near 2000 rpms. it just dies. It runs great everywhere else. I was using a os f, cool power 20% comp heli. 16-12 prop. it turns 8700 rpms. I was running the low end 1/2 turn in from flush and 1 and 1/8 on the high. I have gone a full turn on the low in both direction with no success. I see Troy Newman was running an enya #4 so I thought I would try one. Any thoughts
Could be a heat related problem. Do you have plenty of cooling over the pump? It could also be a bad pump, in which case the engine will need to come see us.
We tuned a DZ a few weeks ago that did the same thing. Poor lower range, idle and died. We wound up with the regulator about 2 to 2.5 in from flush. Then the motor ran perfectly with typical YS response and a fine idle. Each motor takes a little bit different setting. I have seen from 2.5 turns in from flush (rich) to .5 turn out from flush.
Coolpwer 30%, OS F or YS 4 plug are the standards we are using.
Mark
Mark
