Ply Rolled Fuselage Part Deux - 1/2A " Mini Skorch "
#1177
FS .26S vs FA .30Sboth with stock mufflers.
Both with Master Airscrew 9x7 Scimitar S-2 Prop and same spinner.
OS FS .26 Surpass 4 cyl. Static: 11,143 rpm / 2.35 lbs (38oz) / .46hp / 341w / 74 mph / unloaded est 85 mph
Saito FA-30S 4 cyl. Static: 12,273 rpm / 2.85 lbs (46oz) / .61hp / 456w / 81.3 mph / unloaded est 93 mph
Saito wins makes additional: 1,130 rpm / 8oz thrust /.15hp / 115w / 7.3 mph
Without the OS FS-30 to compare displacement wins over design for now.
#1178
Yes the blades are thinner is some regards least around the hub.
Didn't help with the test though as the spinner covered things up.
For wood props the Zinger 8.5x6 will allow the FS-26 to scream
I think for the FA-30 the prop is too small.
Knowing the results of the FA-30
If at 8x9 est 12k static 102 mph and 13.5k / 115 mph unloaded with the engine fully broken in.
If at 7.5x9.5 12k static 108 / 13.5k / 122 mph
So far 8oz ran rich with the last 1/2 oz needle adjusted for a quick power out read.
https://www.youtube.com/watch?v=nRq_Ngbz2iU&feature=youtu.be
#1179
Two items showed up in the mail today the FA-40 size muffler and the APC 8x8 props.
The muffler upgrade helped and I used VP Racing / Power Master fuel for YS / Saito engines
20% all synthetic 20% nitro / bought from the local hobby store today. They are located in TX
I was told they will mix any combo I desire at 4 gallons at a time. 37 years of full scale racing fuel experience.
For hot summer weather this is the ticket but a bit much oil for this time of year. They use Red Line brand oil. 19.95 a gallon here in TX and claim you don't need after run oil because of the brand oil in the mix. In addition they make special blends for car engines, boats, heli and 2 cyl aircraft and CL engines.
http://www.powermasterfuels.com/inde...&id=6&Itemid=8
https://www.youtube.com/watch?v=VyTge_TwGGE From this vid:
APC 8x8 / larger muffler with knuckle
Static: 12.596 / 2.2+ lbs of thrust / .47hp / 352w / 96.4mph / unloaded est 110 mph.
Completing full break in time - new fuel to the recommended 40mins at 4k.
APC 8x8
Static 12,919 rpm / 2.45 lbs (39oz) thrust / .51 hp / 379w / 98 mph / est unloaded 112 mph.
Idles down to 3.2k with this prop non stop steady thru a whole tank. 10x6 it will drop to 2.5k.
Great results, should make for impressive passes for a 4 cyl. engine of this size.
Could nix the knuckle and use a light weight spinner nut to up some more rpm.
APC 8x8
#1180
Sourced a Tru Turn 1/4-28 bullet spinner a perfect match for the APC 8x8 or 8x9 prop
Weight is only 9.4g VS the 2in spinner at 48.1g that many grams less is
enough to add some notable unloaded rpm for speed.
There is a hitch 2in of exposed prop now which could balance the scales.
Perhaps there is a save the APC 7x10 at 13.3k unloaded 126 mph.
#1181
You would really need to be a serious tinkerer to want to modify one of these, though..!
Well, maybe just some higher ratio rocker arms..........
#1182
Bench tested with the fully exposed APC 8x8 loaded down the engine to 11.8k / 97mph thrust was
up but lost 1,110 rpm. It was pulling the wood plank test stand forward. To gain back some
rpm I have on order MA Formula One 9x7.5 will trim to 7.5x7.5 to try with the Tru Turn bullet spinner.
The high pitched APC blades are very thick near the hub, so scored $12.50 to the door ebay bid
Tru Turn FAI 2.25 to completely cover up the fat leading edge area.
To scale a 2.25 FAI spinner.
#1184
Found something small enough for small RC planes in my case the Lil Speedy and 1/2A Skorch.
720P 30FPS quality vid / audio 17.50 free shipping from the US.
Should be able to nail down some good audio data for prop rpm the vid will show
when your on the straights and not diving.
http://www.ebay.com/itm/Hot-Smallest...id=p5731.m3795
11g weight
11g weight
#1185
Guy put his vintage Fuji .049 water cooled / throttled Sea Horse outboard engine onto a plastic airboat.
Heavy but it worked as the stock prop is small enough to endure the load. Very rare to see 1/2A boats
actually recorded on vid for all to see. The modern Fuji .05 in a outrigger hydro should hit 30mph +
https://www.youtube.com/watch?v=SBiq6-_Xtb8 This is just one vid of about 6 that he has on the subject.
#1186
https://www.youtube.com/watch?v=AHsrQ6UMwTU
Uploaded on Nov 27, 2015
Saito FA-30 APC 8x7 Tru Turn Bullet Sinner and FA-40 Muffler
12,600 to 12,760 rpm / 3,875 idle
2.3lbs thrust / 85mph / .43hp / 321w / est. unloaded 98 mph+
Low weight prop /spinner option for minimum engine load.
28.6g prop and spinner nut.
Tru Turn ref:
FAI 2.25" spinner 61.3g with bolt and adapter nut less prop. 80g with same prop / 1.8oz less
Standard 2" spinner 52.4g / with hardware less prop.
https://www.youtube.com/watch?v=X-SjcrdSsi4&feature=youtu.be
Saito FA-30 / APC 8 75x8NN Tru Turn FAI 2.25" Spinner
10,658 rpm / 81 mph / 1.93lbs thrust / .41hp / 306w
Estimate unloaded 94 mph.
Spinner allowed good results despite the weight with increase in dia. and pitch.
The narrow width NN type blades helped prop covers up the aggressive thick
blades near the hub.
APC 8.5x7.5 one to try.
Tru Turn ref:
#1187
That camera is pretty cool. I don't know if it will work on my computer which is XP. I think I could waste that kind of money if it will work on my computer. I know there are other keychain cameras that seem a bit larger. I would guess in a couple years that they will shrink even more, and be better quality too.
#1188
[TABLE="width: 700, align: center"]
[TR]
[TD="bgcolor: #FFFFFF, align: left"]Support System[/TD]
[TD="bgcolor: #FFFFFF, align: left"]Microsoft Windows 2000, Windows7, Microsoft Windows XP [/TD]
[/TR]
[/TABLE]
Yes will work just fine on XP / I still use XP and receive critical up grades and have McAfee
upgrades general software up grades etc. Of course this wont keep going for ever but I
would image you can keep the system safe to use for a few more years.
[TR]
[/TR]
[/TABLE]
#1189
With it cold and wet outside its bench test season.
https://www.youtube.com/watch?v=tvhFJo3Q0dY&feature=youtu.be Tested OS FX .25 ABL
MAC header pipe cut to 4.25 / typical set range is 3" to 3.5"
However I want to use high pitched props.
Practicable rpm to 19k / (.84hp with a 9x5 at 18k)
This is an upgrade over the SF version has a
bimetalic liner two layers rather than one thick layer for more
even / better fit.
Tested APC 8x8
No pressure line needle set tad rich at 2.25 turns / peak is around 1.5 turns with pressure.
About 10mins of fuel ran thru during break in phase so far.
Quick rev up to get a base line reading
16,149 rpm / 122.4 mph / 3.1 lbs thrust / .994hp or 742w
20% synthetic 20% nitro
Will tap for pressure and with the needle dialed in after full break in with the header
trimmed perhaps around 3.75" unloaded est. 18.4k /139 mph.
Should be fun on a 25 size Skorch with a 280 to 300 sq in. wing
https://www.youtube.com/watch?v=fuoQIBwMLVI&feature=youtu.be Tested APC 8x9 with 2in spinner
15,300 rpm / 130.3mph / .95hp / 709w / 2.8lbs thrust
Should unload around 17.2k once all the tweaks are done 147mph
That prop in a dive should bust 150 with ease.
#1190
https://www.youtube.com/watch?v=jLEcY9w8mYU
Published on Nov 29, 2015
Magnum XLS .15A APC 7x5 MACS Tuned Pipe
Break in bench test ran up for a rpm check
Static 18,100 rpm / 86mph /.49hp / 2.3 lbs thrust / 366w
Static APC 7x6 est 17k / 97 mph
6.5x6.5 race prop at 20k unloaded 123mph
ASP .12A MACS 1.5cc to 2.5cc Tuned Pipe
2.11cc engine.
1st test 6.25" header uncut - didn't allow full throttle - rpm / timing off.
At 60% throttle - got on the pipe well and made good power off pipe past that.
APC 6.3x4 20,700rpm. / .41hp / 78mph / 1.82lbs / 306w.
Update APC 6.3x4 with header cut to 3.75" full throttle was possible 20,030 rpm.
Est. 3.25" would be best for this prop up to 21k ish static. Unloaded est. 23.2k / 88mph.
Engine design in stock form requires minimum 5 pitch for speed application to avoid over rev.
2nd test 3.75" header - rpm range suitable for full throttle
APC 7x5 17,118 rpm / .433hp / 313w / 81mph / 2.lbs
3rd test 3.75" header - rpm range good and optimized for unloaded state
APC 7x6 / 15,830 / 90 mph / 1.75lbs thrust / .41hp / 307w / unloaded est. 103 mph+
This prop would be great mix of static thrust and speed
https://www.youtube.com/watch?v=87nuAOFWBMk&feature=youtu.be Published on Nov 29, 2015
4th test 3.75" header rpm still in good range
APC 6.5x5 / 18,980rpm / 90mph /.44hp / 1.85lbs thrust /est unloaded 105 mph.
Prop shape should unload better than a sport prop. Best Prop Tested!
https://www.youtube.com/watch?v=kMO5dXKw52w
Note APC 6.5x5 tested GS Pro V12RR turns this prop static at 21,963 / 104 mph.
Speed tuning needs to be set up for a 5.5x6.5 unloaded est. 120mph
2.11cc engine.
#1191
Did you get the XLS, or is it someone else's? I have been getting a bit better than that with no pipe. Maybe the pipe is too long/short. I made a head that really perked it up. I used the MA 7-5" prop. at over 20,000. Either head is hard on plugs. I had been thinking of getting/making a header and pipe for mine, but heard they are weak cranks.
#1192
Hi Alan,
Yes all these are mine just breaking them in and with some run ups for base line reads.They all need more break in time. Since it's cold out and wet today was a good day for some research and fun with some engine that needed running up. I don't have a pressure line tap yet and had to cover up the exhaust
with rolled up towel exhaust to reduce noise using two hand towels and 1 full size towel. It Also helped to capture oil spray. Might be good for a few hundred rpm gain for each test.
A Master Airscrew has a much thinner blade at the hub, more constant cord props with an even leading edge. I dont have a MA 8x5 to compare nor the modified head. What did you do set yours up for a turbo plug?
Do need to trim down the header pipe its too long at 4.25" I have read for the MACS header 3" to 3.5" for rpm in the low 20's. I am still running bit richer than needed due to this being day 1 run ups.
The engine can run with 8x6 props I'm sure it stresses the crank few bad boinks into the dirt could cause trouble along with a heavy or draggy plane. Perhaps high rpm and high G maneuvers could wang the crank over time along with over heating too many times. Typical props 7x 4 or 5 or 6 or 7 and 8x 3 or 4 or 5 or 6 per the manual.
Plane 1
The ASP .12 has had a full break in hence so many prop tests. I plan to build a plane for the V12RR and do flight testinginsuring the servos are getting the job done no glitches with the ASP before bolting on the extra power and risking the GS engine.
Plane 2
Another goal is build a plane for the bigger case / weight of the XLS .15 that can handle the FX 25 at
some point for more speed.
Plane 3
Also need a general size plane to run the OS 26 and Saito 30 4cyl engines.
Plane 1
Plane 2
Plane 3
#1193
I had to make the turbo plug head from scratch. It was good for 2,500 rpm or so though. Another guy did it and quickly broke the crank. Those combat guys usually like little props though. A larger prop may be fine. I made a bunch of blank heads, and then finished them off separately for each motor. Way over an hour each, and then running, and shimming etc. I think there were over 14 blanks. Made one for the AP .09 and .15, TTiger .15 or .10, which was a useless motor, and LA .15, Norvel .15, LA .25 which made little extra.... The little TTiger .07 head worked well in 2 out of three motors.
#1194
2.5k is a great performance gain Alan, perhaps increased compression in conjunction with the additional rpm
may have stressed the crank, that and flying combat is rough on the engines. I figure if I prop around the max
recommendations from the manuals then unload in the air should be safe enough using the pipe.
#1195
You should be OK under 23,000 rpm. At least the motors are cheap. Kind of hard to find lately. The blue head .15 and .25 are the worlds best kept secret. I think the article that I read about the guy that broke his crank had the crankpin shear off on the test flight. Often that is because the rod to crankpin clearance is too tight, and it siezes, which shears it off. The clearance seems too big sometimes, and that could be bad too, so it is a crapshoot. I think .002" to .003" is where you want to be. .003" would seem pretty sloppy.
#1196
I have been quite pleased with the ASP .12 shows good promise as it was originally made for cars.
Curious what's under the hood to help it make the rpm required for cars, I wanted to look at the sleeve.
To my surprised they have the 3 transfer ports open from the ground up. This is the only engine on
hand cut through all the way seems like a simple solution for big gulps of air and fuel.
#1197
The .09 and .15 are the same design, but the .09 does not get milled right through. The Fora .049 is similar to the AP.09, but the bottom of the cut is curved somehow. The .09 sleeve is shown here beside the .15 motor which has the finned head, the .09 is a smaller dia. and has no fins or anodizing. The .15 is really just a .135. They both responded fairly well to a turbo head, but not as much as the blue head one. The LA .15 did not respond very well compared to these making me think that OS spends more time developing their motors.
#1198
The new micro size video cam came in all up weight 10.4g has a lithium battery and requires a micro SD card.
I will try a 1G card and see what 2MP 640 x 480 30fps will use up duration wise then decide on the right card for the
job I will need enough vid time to test out 2 to 3 props is all on any given outing. 10.4g with SD card mounted.
I have done a brief test at home works fine and sound is good. Will post a vid with in flight rpm data next day
at the field. This one's size and weight is low enough to use on a TD .010 size plane if desired.
On the box mine says Y2000 17.50 shipped.
Here is a vid of one similar:
https://www.youtube.com/watch?v=CgtTg62GDfs
for 9 bucks more you get
- Y3000 Mini Video Camera 8MP
- Video resolution: 1280 X 720@30fps.
- Picture mode: JPG.
- Picture resolution: 3264 X 2448.
#1200
Ya, I wonder as well. I have a theory that downhill makes more difference than the wind. When flying control line on a very windy day I have noticed that you walk slower and faster. You can see the plane go much slower and then speed up. Naturally the lines curve in when slow, and it wants to go slack, so there are other elements to change results. The revs sound the same pretty much. The doppler effect is not noticeable from inside the circle. I noticed a Polaroid cube camera that looks interesting as well. I'll wait for Pond Skippers results anyway. It is getting too cold to fly here.
