jamara pilatus turbo porter arf?
Loopman, I also own a Jamara Porter. The only thing left to do is install the engine & tank. I'm thinking of using an Saito 150. I have one on hand, what do you think? I've been undecisive for some time now. I thought about mounting it inverted, but again, I don't know. I also upgraded to sullivan pushrods, and heavy duty control horns for the elevator. I went with the supplied ball links and servo hatch provided. I thought the kit was excellent even though the instructions were in GERMAN! But, after many hours of staring at the pile of parts, I got it all together. My gas grill was'nt as lucky!! I thought about installing a hatch to access the fuel tank/fire wall. There is no way my hand will fit in there! Anyway good luck with yours, keep us posted
My Feedback: (195)
GA
Pilatus Porter
Shotguneddy,
I lost my first Pilatus when my home burned but have since replaced it. It is awaiting construction at a friend's house. My ST2300 was damaged in the fire and I have replaced it with a Saito 150. I hope to have it in the air within the next month or so. I believe the linkages supplied will be sufficient but I still plan on replacing the control rods with Sullivan "Precision" rod. I believe I can get the fuel tank installed without installing a hatch. Hope you enjoy yours, let me know how it goes!
Happy Flying!
Loopman
Happy Flying!
Loopman
Loopman, Sorry to hear about your house. As I'm mailing you at this moment from a Fire Station, I can feel your pain. Glad to hear your back on the RC track and got a new Porter. I hope the insurance company ponyed up for it!! I will keep you updated.
I just bought the jamara porter. It is a Jamra Blue and silver with 95in wingspan. I got it from EMA ion Texas and it came with no instructions at all. I am puzzled about how the struts are mounted. It is a Jamra Blue and silver with 95in wingspan. Is there supposed to be a fitting on the fuse to receive the aluminum angle iat the end of the strut? I dont see any appropriately reinforced spot on the fuse and wondered if you got any instructions that showed how the strut is mounted. On the wing there is a ply section with a 1/4" whole to accept the fitting on the upper end of the strut but how do you fasten it? I noticed that you had a post about this plane and wondered how you anchored your struts. Alsoo what engine did you finally use? I was going to try a saito 72 4S.
My Feedback: (24)
Originally posted by gjlazar
I just bought the jamara porter. It is a Jamra Blue and silver with 95in wingspan. I got it from EMA ion Texas and it came with no instructions at all. ... Alsoo what engine did you finally use? I was going to try a saito 72 4S.
Also, did your kit come with a blue tail, or white? And is the cowl white, or blue and silver (or were there blue and silver decals for it)? Their web site photo shows a blue tail and blue and silver cowl. Given they charge $30 extra for the blue and silver version, I feel this is unacceptable. Again, I emailed them about it, and we'll see what they say.
I was thinking of using an RCV 120SP in it. It looks like it would fit perfectly under the cowl.
#32
RE: jamara pilatus turbo porter arf?
Just go my jamara pilatus porter 96" ARTF seems nice kit but all in German
Achtung
Anyone know the CofG and throws recommended ?
Also I need a good 30mins flying time and I think the 14oz 400ml supplied tank a bit small for a 2stroke 1.08 or ST2300 any suggestions on tank size for 30 mins otherwise i'm putting in a 24oz or 32oz tank ?
ta
Alistair
Achtung
ta
Alistair
#33
FL
RE: LAST one
I BELIEVE I HAVE THE SAME ARF PORTER YOU HAVE. CAN YOU TELL ME WHERE YOU BOUGHT IT.
INEED NEW WINDSHIELD AND COWLING.
I USE TO FLY IT WITH A U.S. ENGINE 41cc NOW I AM INSTALLING A FUJI 32CC.
THE PLANE HAS ALWAYS FLOWN GREAT. I WOULD LIKE TO MAKE SLIDING CARGO DOORS AND ADD A SKY DIVER.
[img][/img]
[img][/img]
#34
My Feedback: (77)
KY
RE: LAST one
I have a Porter like the one pictured above. This is the early, non-turbo version. I believe it was a Czeck ARF. No Dihedral, bolt on tail and rudder.
I am flying mine with a First Place Engines 1.3, and it flies very scale. Everything fits in the cowl. I imagine a Zenoah, G 26, Fuji 32 or G 38 would be great. I also know people have flown these with 50's for glider towing.
I believe the wingspan is 80". I used Hobby Lobby servo pockets, and reversed them, gluing them into the wing, to make a removable servo system. THe only thing touchy was cutting the windscreen.
I don't know anout the Jamara version. It looks good though.
#39
RE: Jamara Porter
Loopman
I have a Jamara Porter 95" wingspan but have no idea what the correct C of G setting should be, do you have any idea? I had no instructions to work from!
Paul
#40
My Feedback: (10)
OR
RE: Jamara Porter
ORIGINAL: jumppilot
Loopman
Paul
Loopman
Paul
Center of Gravity 95mm behind the leading edge (very good location, very stable )
Elevator 18 mm on both sides
Rudder 50mm on both sides
Aileron 30mm up, 25mm down
Flaps 30mm down
These are the recommend beginning settings and work quite well. I have English instructions if you have any questions. They are a poor copy but I could try and copy them for you if you like just let me know your email address.
#41
RE: Jamara Porter
Wow thanks buddy, I will set it to 95mm and see how she flies. pilot69(at)btinternet.com is my e mail address if you have anything else to send. Your a star!! Thanks. I will place a video on youtube of it if all goes well.
#42
My Feedback: (10)
OR
RE: Jamara Porter
Send me the video link when you post it. I emailed the instructions. Note that the Hatch on top will blow off unless you come up with an additional latching system. I just used 2 strips of velcro myself.
#43
I just finished one and flew it this past weekend. Here's some info:
Flaps 30mm down
Flaps 30mm down
I have just been given a jamara 95" pilatus porter and I have found this old threat. It is the same blue/ silver model that is above.
I'd like to power it with a gas engine but I am not sure if the firewall will be strong enough for a gas engine. I have to decide between a dle 20cc ra or a dle 35cc ra.
Any recomendación or advice from someone that had this plane would be appreciated
