Brushed/Brushless motors, speed controls, gear drives Discuss all aspects of brushless motors, brushed motors, speed controls (ESC's), gear drives and propellers in this forum.
Is my Pheonix 25 'tarded?
Old 02-19-2005, 12:21 AM
GordonFreeman
GordonFreeman's Avatar
Default Is my Pheonix 25 'tarded?
Last year I bought a Pheonix 25 and a Himax 2015-4100 for a hummingbird. The only experience I had with brushless was the Novak 5800 system. I don't know the definition of cogging, but I will assume it means the inability for a sensorless system to start or have proper control at low speed.
The hummingbird always had "cogging" problems. If throttle was applied, it would kick back and forth and never start up in one direction. The motor itself would run just fine, it was just when mass was added to the rotor. Didn't matter what settings the ESC was set to, soft-start, timing, ect...I always had to spin the rotor by hand and give it some throttle to get it started. OK, no big deal.
So I put the system in a 1/18 scale Xray car. Same deal, I'd have to push the car while holding a bit of throttle to get it started. By the way the car was ballistic! Ok, no big deal.
Now I have myself a Tensor. I bought the E-flight 370 1080kv motor for it. Guess what, same friggen problem. I can't even get a prop to start up, not even by spinning it up by hand. The only way I can get the motor (the outrunner) to run is without a prop AND to spin it up by hand.
Is this typical "cogging"? If so I can't believe how lame this sensorless stuff is. Do I have a bad speed control? If so, what is wrong with it? Why does it work once the motor is "up to speed"?
I don't care who or what is to blame, I want to understand what is going on here. Seems like this sensorless stuff is lightyears behind sensored. I simply want to have a system that works. I will buy whatever is needed for simple, trouble free operation.
Thanks.
Old 02-19-2005, 05:40 AM
BadSplice
BadSplice's Avatar
Default RE: Is my Pheonix 25 'tarded?
I have a park370 5400kv, and a himax 2812-0850 outrunner, (and the CC10 and 25) I know others with similar setups. I have never heard of this problem. I would suggest that you find someone with a brushless system so you can figure out which component is to blame, then contact the manufacturer for a replacement.
Old 02-19-2005, 06:58 PM
GordonFreeman
OK, I should be able to try out some different components this week. But here's another interesting little tidbit.
The motor will not start with it mounted in the plane. It will (reluctantly) start if I take the motor out and mount it to a 2x4! It still cogs badly before it starts but it will reliable start when mounted to a solid object. I still think something is wrong and it is obviously amplified when the motor is mounted in the plane (flexible).
Old 02-19-2005, 11:46 PM
Trogdor the Burninator
Trogdor the Burninator's Avatar
What you are describing is a fairly common problem with earlier revisions of the castle creations firmware on the controllers. You should email them and they will likely reprogram it and send it back for free... I had the same thing on my 25, not as bad as yours but sometimes made me think the motor mount might bust off.. I just dealt with it until this winter and they had me send it back. Seems to be running fine now. Haven't noticed any of the stuttering yet but only have made a handful of flights.
Old 02-20-2005, 10:50 PM
GordonFreeman
FYI, I bought a new Pheonix 10 and everything works perfectly. There is definitely something wrong with the older Pheonix 25. Hopefully CC will take it and update for little or no cost.
Old 02-23-2005, 04:18 AM
petri
Had same problem with an early CC Pheonix 25, just get the USB cable for about $20 and you can reflash the software to the latest version. It prompts you for it as soon as you hook it up to your PC, if you don't have the latest software revision. It makes programing all the options alot quicker too.
Old 08-29-2005, 05:10 AM
GordonFreeman
I sent it in and Castle Creations fixed it up for no charge. Works great now!
Old 08-29-2005, 08:05 AM
jdetray
jdetray's Avatar
Hi Gordon-
Glad you found the problem. By the way, the problem you describe is usually called "stuttering." Cogging is the resistance you feel when turning an unpowered brushless motor by hand as it jumps from one magnet pole to the next.
- Jeff
Old 12-17-2006, 08:34 PM
Haulin Azz
Haulin Azz's Avatar
so the pheonix-25 esc will work in a 1/18 car. i bought the pheonix-25 esc and the new cobalt 5800kv brushless motor to go in my 18 t will the setup work?
Old 12-18-2006, 11:22 AM
pilotpete2
pilotpete2's Avatar
Hi Gordon,
Isn't it nice when a company gives good service[8D]
I'm just goin to "second the motion" that you consider a Castle Link cable in the future, much easier to program, especially the LVC for Lipos.
Cheers,
Pete
Old 12-19-2006, 08:57 PM
Joe Ford
Joe Ford's Avatar
Custamizer...you won't want to use the Phoenix controllers in a car. The software is totally different...the controller will arm at full brake/reverse (thus, no brakes!) and neutral will be 1/2 throttle. Mamba 25 is the way to go.
