Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Gruman Ag-Cat
Old 04-06-2008, 09:40 AM
  #126
Agpilot25
Default RE: Gruman Ag-Cat
I am building the 90'' agcat from Floyds plans. I am trying to figure out what engine to use. I wanted to put a Saito 325 radial but my funds just doesnt allow that I was wondering what 4 stroke I could use? A saito 170 radial or 200 single cylinder? What would you guys recomend I am going to put a hopper and spreader on it to simulate dust.
Old 04-06-2008, 10:16 AM
  #127
gjmjoe017
gjmjoe017's Avatar
I am sure some other guys will jump in on this,but the Saito 220 is only 36cc displacement and this plane will probably come in at 25lbs or more.One of the guys is using a 3w 75 I think and I would think it would take at least that to give it good power.Just my two cents.
Old 04-06-2008, 10:41 AM
  #128
outacontrol41
My Feedback: (9)
outacontrol41's Avatar
I'll jump in. You might consider getting this bad boy....a lightweight 50 cc. This will haul the AgCat around with ease. I don't know of any 4 stroke that will haul a 25 lb. plane. On the other hand, if you try to build light and your plane ends up at about 20 lb. AUW you may be okay with that Saito.
BTW, check out the price of the XYZ 50, read A-F-F-O-R-D-A-B-L-E !
http://www.southeastengines.com/see_002.htm
Old 04-06-2008, 11:27 AM
  #129
gjmjoe017
gjmjoe017's Avatar
The other 50cc to look at is the DL 50.It's a knock off of the DA 50 and there are some really good reports on how well it runs.
www.dlusa.net
Old 04-06-2008, 12:28 PM
  #130
outacontrol41
My Feedback: (9)
r u sure that's the correct URL address?
Old 04-06-2008, 12:30 PM
  #131
gjmjoe017
gjmjoe017's Avatar
Sorry about that,it's
www.dlusa.net
Those .net will get ya every time!!!
Old 04-12-2008, 06:12 PM
  #132
Agpilot25
I appreciate the help on engine choices I finally decided to save up and get the saito 325 radial it just sounds so good. I am a cropduster and fly an agcat myself so I just got to get the radial for it. Also what are you all using for flying wires?
Old 04-15-2008, 06:24 PM
  #133
mac49
Ok here''s the gear. I tried to follow Floyd''s plan but my over-engineering got the best of me. The LG is made by TNT from 5/16" 6061, wheels are 8.5" from a mountain skate board. They come with 10mm bearings and I''ve inserted bushing I made at home from stock bought from Aricraft Spruce. The fuselage where the LG attaches is not quite 1/4inch ply with a 1/8 door skin doubler. I used a 2 inch wide by 3/4 inch fir backer for the LG. There are a couple of 3/4 inch plywood clamps on the end to help spread dynamic loads to the doublers. Its all glued and screwed together. It''s attached with six 10-24 cap screws with nylock nuts. The tailwheel needs more work. I manufactured it from 1 1/2in x 1/4 in 6061 bar stock. I didn''t get it bent as nicely as TNT. The caster frame is cut from 3/32 in 3003 and also needs some correction. Thats a 4" Dubro wheel but it wan''t ment for a tail wheel. I''m probably going to need to drill it out an put in a brass tube insert.
ID:	929935   Click image for larger version
ID:	929936   Click image for larger version
ID:	929937   Click image for larger version
ID:	929938   Click image for larger version
ID:	929939   Click image for larger version
ID:	929940   Click image for larger version
ID:	929941   Click image for larger version
Old 04-15-2008, 07:48 PM
  #134
outacontrol41
My Feedback: (9)
Nice work so far. Looks really huge.
Old 04-15-2008, 09:53 PM
  #135
mac49
I''m actually working in the living room of an old cottage my wife and I own. Gives me a 13 X 15 foot work area. (I also have the rest of the house but the rooms are pretty small. You get use to the pink interior after awhile.) I don''t have the 4 X 8 foot work bench situated where I can assemble it. ( I have a row of book cases taking up the wall opposite the window in front. I clamped it together a few weeks ago to get the feel for how it is going to go together. Looked pretty good to me. It took up most of my side of our two car garage. My wife''s Pathfinder sat on the other side in the photo. It will certainly look nice parked on the runway the first time after I get it done. It''s going to be a while though.
Old 05-08-2008, 11:59 PM
  #136
outacontrol41
My Feedback: (9)
Keith....
What's the latest on the DH Ag Cat ARF development? Been quiet here for a while....
Old 05-15-2008, 11:15 AM
  #137
RedTwilight
RedTwilight's Avatar
ORIGINAL: outacontrol41
Keith....
+1 How's the build coming?
Old 05-17-2008, 08:56 AM
  #138
wiz310
are you familiar with the Saito FG36?. a big four stroke gasser. will haul that bad boy around with ease and sound good, as well as giving you a nice slow idle and fly on tiny amounts of fuel.
thread is here. http://www.rcuniverse.com/forum/m_5041020/tm.htm
Old 05-17-2008, 12:31 PM
  #139
51-D GUY
Hey Keith,
What's going on with the Ag-Cat ARF ?
Send us some pics, Any info on when the kit's will be available ?
Give us a Update !
51-D GUY.
Old 05-19-2008, 12:23 PM
  #140
rychaross
Hey guys,
Sorry for being so quiet, but just getting finished with baseball. I haven't been able to commit much time to the project, but I have made some small increments of progress. I'll try to post some pictures soon once I get rolling again.
Old 05-19-2008, 01:01 PM
  #141
Hill202
My Feedback: (24)
Hill202's Avatar
ORIGINAL: wiz310
FG36 on a 25lb plane?? I don't think so
Old 05-19-2008, 04:55 PM
  #142
rychaross
Duane is still trying to pull all the #'s together on labor/cost. When he finally determines the cost of the kit he will also probably committ to a production start date. Sorry, but that's about all I have right know.
Old 05-19-2008, 05:23 PM
  #143
outacontrol41
My Feedback: (9)
I can live with that for now. There's more than a few of us out here waiting....[8D]
Old 05-19-2008, 09:00 PM
  #144
51-D GUY
I Know the feeling , Not enough hours in a day !
I spend more time working on other peoples planes than my own !
then when i think i have time, i have to do something else.
I'll be watching for the pics, Jason 51-D GUY.
Old 05-22-2008, 01:49 AM
  #145
anothercrashpilot
[sm=what_smile.gif]........HEY ,! ! ! Outacontrol,,,,,,,,, "GET THIS",.......... After Repling to you on Austars, ,,I got an EMAIL from the CUTTER saying he'll be FINISHED with MY kit AND extra wing set in a few days ! ! ! [sm=72_72.gif] Just not too sure WHAT to think about it any more ! ? ! ? ! ........... That big ole AGHuskey sure Would be nice ? ! ? ! AAAAAAAHHHHHHHHHHHH ! ! ! ! ........O.K....AG-Cat. first.................................... I just hope I can FIND Time to WORK on it now ! ! ! !!
Old 05-22-2008, 08:10 AM
  #146
outacontrol41
My Feedback: (9)
a FEW DAYS = a few WEEKS?? Not an unreasonable question at this point. Let me throw some sad truth at you, and this really is the truth....IT DOES NOT TAKE THIS LONG TO CUT A KIT! You should have been flying that plane by now. []
Old 06-19-2008, 05:52 PM
  #147
gjmjoe017
gjmjoe017's Avatar
Hey Keith,what the heck is going on with this ARC project for the kits.Any progress??Hope it's not dead!!
Joe
Old 06-19-2008, 08:38 PM
  #148
outacontrol41
My Feedback: (9)
Keith....
I don't like to repeat myself, so...........[sm=confused.gif]
Old 06-20-2008, 01:19 PM
  #149
D.R.BOWERS
Hay mac49, you are doing a great job on the AG-CAT. What are you using for wing ribs?
Good flying.
Dale
Old 06-23-2008, 04:50 PM
  #150
rychaross
Hey guys,
Sorry I've been so silent lately on the D.H. Agcat. I've changed jobs during my last post. After 18 years with one company I've decided to expand my horizons.... I'm still working on the Agcat, but it is going slow. I want to insure that the proto-type has that WOW factor that we've all been waiting for. I haven't talked to Duane for some time now. I know he's been helping his son with his business....so he's been extremely busy with that. I will do my best to call him this week. I believe Duane is laying more fuses to get ready to produce the kits, but I will update you guys after I talk with him.
_____________________________
Brian Keith Fontenot
