Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
World Models 1/3 Super Cub
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 07-18-2010, 09:19 PM
  #326
sweetpea01
My Feedback: (10)
Default RE: World Models 1/3 Super Cub
Not in the Clipped cub.
Old 07-18-2010, 09:21 PM
  #327
flyinucrazy
My Feedback: (107)
I have the super cub, will it work without cutting the cowl?
Tim
Old 07-18-2010, 11:29 PM
  #328
sweetpea01
My Feedback: (10)
Not sure on the Super Cub.
Here's a quick vid of my latest mod to my Clipped Wing Cub........the actual drop
[youtube]http://www.youtube.com/watch?v=VMwjiRixQJA[/youtube]
Old 07-22-2010, 12:30 AM
  #329
zdsh13
Finally got mine ready to fly, hopefully next week will be the maiden. I was hoping to minimize the cowl cutting but the dam mufflers extended too far forward to not cut the cowl.... a normal cub cowl and I would have been ok...
I installed a 3W-78ib2, hopefully it will be enough.
ID:	1471561   Click image for larger version
ID:	1471562   Click image for larger version
Old 07-22-2010, 05:50 AM
  #330
ROBERT C. KLINE
I put a 3w 106 in my clipped wing cub and cut just what I needed to fit in cowl and the motor overheated and lost the intake seal. You may want to check with others, but I think you do not have enough exit air opening around the exhaust tube area. Just a thought to check into. Enjoy the cub and you will like the motor. My 106 is excessive and I think your 78 will be fine.
Old 07-22-2010, 08:47 AM
  #331
glowplug50
Rule of thumb has always been twice as much area going out as is going in for good cooling.
Old 07-22-2010, 09:40 AM
  #332
zdsh13
ORIGINAL: glowplug50
you can't see the openings in the pic but behind the exhaust stacks I needed to open up quite abit to be able to get the cowl to slide over to install the cowl. I'm well over 2x the inlet/exit ratio.
Old 07-22-2010, 01:00 PM
  #333
glowplug50
I guess the real question is "how much going in is suficient?'. Hard to determine I imagine but as much as possible without destroying the looks of the aircraft (when possible).
Old 07-22-2010, 09:47 PM
  #334
zdsh13
Another option is to better use your inlet air by baffling to ensure the air flows over the cylinders, I might do this yet as it would be simple to fiberglass some baffles in the cowl.
Old 10-26-2010, 01:56 PM
  #335
Billy
My Feedback: (15)
I was thinking of setting up one of these for a camera ship. How much weight do you think it can reasonably lift?
Billy
Old 10-26-2010, 02:01 PM
  #336
jbarnes
Its like a giant sailplane. It could easily handle 10 lbs of cargo. Jerry.
Old 10-26-2010, 02:57 PM
  #337
ROGER RUSSELL
My Feedback: (12)
ROGER RUSSELL's Avatar
This is the 1/3rd CUB not Super CUB with a GoPro camera mounted on it.
http://www.youtube.com/watch?v=vz0H5MgM0_8
Old 11-04-2010, 11:52 PM
  #338
zdsh13
I finally got a chance to maiden my super cub, what a floater Had a slight wind down the runway and the plane lifted off in about 30 feet at under 1/2 throttle.... With flaps down I would estimate the ground speed was at 7 mph with the small head wind, aerobatics not so great but for a relaxing airplane to fly this is it....
Engine: 3W-78ib2
Prop: Mejzlik 26x8 6500 RPM
Old 11-05-2010, 01:00 AM
  #339
Billy
My Feedback: (15)
Very nice. Are those the Bill Hempel 60% cub wheels? I like the "bush" look.
Billy
Old 11-06-2010, 03:44 PM
  #340
zdsh13
ORIGINAL: Billy
Very nice. Are those the Bill Hempel 60% cub wheels? I like the ''bush'' look.
Billy
I think they are smaller.... 40% but not sure..... The diamerter is 6", I bought them on Flying Giants.
Old 11-07-2010, 12:43 PM
  #341
GoeKeli
My Feedback: (18)
GoeKeli's Avatar
Billy, should we get us a couple of these? When are they back in stock?
Old 11-07-2010, 02:13 PM
  #342
Billy
My Feedback: (15)
Hey Joe,
Airborne will have them in Jan. I have been looking all around and they are no where to be found. I have my wheels already though
It would be fun to fly them around at the basin. Easy, relaxing flyin'.....touch n goes all day
DO IT.....DO IT....................DO IT.
Billy
Old 11-07-2010, 04:45 PM
  #343
sweetpea01
My Feedback: (10)
Nothing like a Giant Cub to just relax and fly with. When you add Smoke and my Bomb Bay it just takes it up a notch!
Old 11-08-2010, 12:26 AM
  #344
GoeKeli
My Feedback: (18)
GoeKeli's Avatar
It's very tempting and I've got a DA100L and all the electronics right here.
Old 11-08-2010, 11:41 AM
  #345
Billy
My Feedback: (15)
Issac at the field has a Balsa USA one 1/3 that he is selling. Call him. I am actually going up North next Sat to pick one up from a guy.
Later Billy
Old 02-15-2011, 02:09 PM
  #346
Hammbone
My Feedback: (309)
How hard is it to install floats on this plane?
Would someone please share what's involved with installing floats?
Thanks, Jim
Old 02-20-2011, 07:32 AM
  #347
airbornrc
My Feedback: (9)
AllI did is add a 1/4 ply plate in the bottom for the rear struts to mount to the front goes to the factory gear location.
ID:	1566926   Click image for larger version
Old 02-20-2011, 07:43 AM
  #348
Hammbone
My Feedback: (309)
Thanks for the reply. Sounds easy enough.
What floats did you use?
Thanks, Jim
Old 02-20-2011, 08:13 AM
  #349
glowplug50
Here is an old favorite link to some vintage float instruction. http://www.seminolerc.com/EZ-Float-Design.html This is an old article from the 80's.
Chuck Cunningham was a float flying guru back then and his information still pertains. He recomends a float that is 75 to 80 % of the distance from the prop hub to the rudder line. I would recomend the 80 %. Not as pretty but much more functional. The tip of the float must project beyond the prop or you wil experience lots of bad! Anyway, it is a starting point. Just make sure to rebalance the model and keep them as light as possible. Planes with floats do not recover from spins near as well as with out them. Personal experience.
Have fun
Old 02-20-2011, 06:50 PM
  #350
airbornrc
My Feedback: (9)
Built my own with help of a friend. We band sawed white foam to his templates. Then I put a single layer of 6oz glass cloth on with epoxy. Filled and painted them. Built and installed in two weeks. They are only 5lbs complete. Has been a blast and always draws a crowd.
Last winter I stripped the covering, Put all the servos inside, added a light system and recovered it with Stits fabric. added a couple of pounds but it still floats like a glider.
Mark
