Reload this Page >
***CUB BROTHERHOOD***
Old 11-10-2014, 03:45 PM
  #2951
meanrc
Cub Man
I have been off the air for some time but I just made a madest donation and I hope all will do the same. We all need the web site up and running
Cheers MEANRC
Old 11-13-2014, 09:23 AM
  #2952
Cub Man
My Feedback: (50)
Cub Man's Avatar
Thanks for the donation.
I have added a new section to the website. Full Scale. Check it out, I have handbooks and stuff for J3, L4 and PA18 Feel free to send me stuff to add. may soon add some links to full scale builds and rebuilds.
Old 11-13-2014, 01:28 PM
  #2953
spaceworm
"Correct Procedures for Rigging a SuperCub
Per Piper Service Bulletin 910A, Service Memo No. 19, the procedure for rigging a
PA-18 and PA-19 is as follows:
Rigging Procedure: Raise the forward part of the airplane so that the wheels are just
clear of the ground, and support it by props under the front landing gear fittings. Raise
the tail to approximate level flight position and support it there.
Leveling:
Level the airplane as follows: Drop plumb bob from P. K. Screw in door
frame top channel to intersect punch mark in enclosure door rear hinge.
Dihedral Angle:
To check Dihedral angle at the front spar, proceed as follows:
Stretch a string along the top of the wings above the front spar, from wing tip to wing tip,
and draw it tight.
Check the dimension vertically from the string to top of fuselage front spar wing hinge
fitting. For correct dihedral this dimension should be 3 1/8 inches.
To check for equal Dihedral in each wing, proceed as follows:
Using the 30 inch level (without any spacer blocks), hold it spanwise against the bottom
of the wing under the front spar in the space between the jury struts and lift strut
attachments. Note the position of the bubble and do the same on the other wing. Readjust
the front struts until both wings show the same amount off level, being careful with
each adjustment to set the left strut out the same number of turns as the right one is set in,
and vice versa.
Wash out:
To adjust the wash out in the wings (dihedral of the rear spar), proceed as
follows:
Set a 3/8 inch spacer block on top of the 30 inch level at one end. Working on the rib
adjacent to the outer end of the aileron, hold the level fore and aft along the bottom of the
rib with the spacer block at the rear and the front end of the location of the front spar.
The correct wash out will exist when the bubble is centered. Adjust the rear struts in or
out to obtain this condition.
Tail Assembly
: With the airplane in level position, the stabilizers should be leveled at
their rear spars. The hinge line should be straight from tip to tip.
Plumb the fin at the rudder hinges."
Sincerely, Richard
Old 11-13-2014, 09:26 PM
  #2954
ARUP
My buddy, Warbirdmustang, took a couple of pics of my Taylor J-2 Cub yesterday.
Old 11-14-2014, 08:01 AM
  #2955
FlyerInOKC
FlyerInOKC's Avatar
Love it ARUP!
Old 11-14-2014, 11:52 AM
  #2956
cubcrasher
That looks sweet. That is the one you made from
the Goldberg kit isn't it?
Old 11-14-2014, 05:40 PM
  #2957
ARUP
Thanks Guys! Yes... it is a highly modified Goldberg Cub. Like all Cubs it flies great! It still retains the one piece wing but the whole thing is built lighter. The OS40 four stroke is plenty of power. It'll take off grass and climb out at 1/2 throttle using an 11x6 prop and 10% fuel with added SIG castor.
Old 11-14-2014, 10:38 PM
  #2958
cubcrasher
Cool, I have one of those kits and I was thinking of making a "stand way off scale"
Tri Pacer with it.
Old 11-15-2014, 02:30 PM
  #2959
ARUP
I always thought it would make a nice E-2 Cub! Just think... no fin-fuse fillet and nice 'square' tail feathers and wingtips! Pretty color schemes abound and you never, ever see them!
Old 11-15-2014, 03:17 PM
  #2960
cubcrasher
That is actually a versatile kit.
Old 11-16-2014, 07:42 AM
  #2961
TonyBuilder
TonyBuilder's Avatar
I am assembling a Bill Hempel 40% super cub, I have been looking to build a giant cub but I don't have the space to do such a kit build so I chose the BH ARF. I will be detailing the ARF as much as I can (I have to do this to any ARF I fly). My plan is to fly it for a season then strip the covering, do my modifications and cover with a paintable fabric.
Count me in on the brotherhood.
here is the look I am going for.
TB
ID:	2047811   Click image for larger version
Old 11-16-2014, 10:29 AM
  #2962
Super08
Super08's Avatar
Nice. I did a quick search on the first one and it is based about 40 NE of Toronto. It used to be a "N" registered plane but was imported to Canada in 2003.
Old 11-16-2014, 10:37 AM
  #2963
TonyBuilder
This will be the ARF version. I don't know what scheme I will do when I recover it, may clip the wings once I see how it flies.
TB
Old 11-22-2014, 10:09 AM
  #2964
smkrcflyer
smkrcflyer's Avatar
Flew my Eflite Super Cub today for the first time. Very nice plane no issues at all with the first flight. It got a bit windy so we only made the one flight. This plane has lots of scale details like flaps, functioning landing and fuse door that is split in two pieces. I used the power 25 with a 4S pack and it was good power for the plane does not need anymore. Flew it at 1/2 power most of the time. Landing was easy with no issues.
ID:	2049317   Click image for larger version
ID:	2049318   Click image for larger version
Old 11-22-2014, 04:37 PM
  #2965
acdii
Finally got the cowl opened for the Saito 100. Started painting it, then I can finish up the engine install. Then install the doors, and hook up the pushrod and rudder controls. The last step then are the windows.
I had to take a lot more out of the cowl than I had planned for, but it was the only way I could get the cowl over the motor.
Old 11-22-2014, 05:46 PM
  #2966
cubcrasher
Lookin sharp there acdii
Old 11-22-2014, 05:59 PM
  #2967
acerc
acerc's Avatar
Yes indeed, very sharp!
Old 11-23-2014, 06:24 AM
  #2968
OLDFLYER2
OLDFLYER2's Avatar
Nice work. If you look at a full scale cub cowl it is cut out a lot more than that and it splits in the middle. Just sayin.
Old 11-23-2014, 08:26 AM
  #2969
acdii
My biggest concern was having to cut the cowl at the fuse to make it work, which reduces its overall strength and shape. I have the first coat of dope on it and it looks pretty good, should have it done today.
Old 11-23-2014, 11:06 AM
  #2970
Cub Man
My Feedback: (50)
Cub Man's Avatar
Come on guys. We had a lot of you wanting brotherhood shirts. Now we have the design I'm looking to sale a few more. Total of 7 sold already. Was shooting for 20 total. Guys I have them for sale on the store front on my site. I'm not making anything on them.
Old 11-23-2014, 12:03 PM
  #2971
acerc
acerc's Avatar
I will order one Thursday Charles.
Old 11-23-2014, 01:36 PM
  #2972
cubcrasher
Cool lookin shirt. I don't care what you make on it. I want my shirt.
Old 11-23-2014, 02:27 PM
  #2973
acdii
OOOH my Cub is looking good. Winders are in, Cowl is painted, Engine fitted and plumbed except I forgot to set the throttle position to closed, so I dont know if its open or closed now without removing the cowl. I got the elevator pushrod in, now to attach the control arm to the elevator and set the throws. ALso have the tail braces to do and the pull pull. Once those and the throttle cable hooked up, and the windshield painted, the Fuse is done! Thine its just finishing the wings and struts.
Old 11-23-2014, 03:41 PM
  #2974
ARUP
That's gonna look great toolin' along!
Old 11-23-2014, 04:01 PM
  #2975
acdii
On the struts I am going to paint the front one blue, and the rear one red. Not sure about the brass part on what I want to paint that part as. I may try to polish it and clear it instead. I am really thrilled in how it came out. I fudged the cowl a little by not waiting long enough before pulling the tape off and took a little with it.
