Spinner problem
NY
Spinner problem
Hi all,
I'm trying to install a Great Planes 2-1/2" aluminum spinner on my Magnum 61 2-stroke, w/APC 11x7 prop. I bought the 5/16 adapter for the shaft, (threads in end for spinner bolt). The adapter set comes with a washer that accepts the shoulder of the nut. I have WAY too much prop shaft left and the nut/washer is nearly 3/8" from tightening when it bottoms out on the shaft. Suggestions?
