Help with lipo receiver pack
Hi I needed help with the lipo for a spektrum receiver and hitec servos, obviously I need to knock down the voltage for the servos so would a regular castle bec do it?
Also the lipo I was looking at has 2 plugs, would it be ok to plug one into the rx and one into a gas ignition? Would they both get 7.4 volts or would it cut them in half?
I think the rx and ignition will both be ok on 7.4 at least that's what I've been told, that it's only the servos that needs to be knocked down. I do have planes with regulators but to keep it simple I would like to use the bec if possible and only have one battery to keep it light. Any help would be great
Moderator
You can't run the receiver/servos and the ignition on the same circuit. You'll get interference that way. You'll need an optical isolator for the ignition. The simple way is to run an optical kill switch which will both isolate the the ignition circuit and give you a way to shut off the engine with your radio. Then you'll have a choice between running both circuits from one BEC or using separate ones.
MI
7.4v is the nominal voltage of a 2 cell lipo. Fully charged it will be at 8.4v. I dought your Spektrum rx or the servos will handle that. You will need a regulator to drop the voltage down.
Dle 30, 6 hitec 5645s, ar8000rx
I think the ignition and rx are good up to like 9 volts but if I have to regulate the servos the rx would have to be regulated to right? I found this on hk but don't know if 5 amps would be enough,
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Says you can run 2 lipos 2 rx and such so I was hoping I could use one for rx and one for ignition
Moderator
Without optical isolation of your ignition circuit from your receiver circuit, any interference that your ignition makes is going to go right to your receiver. Yes, 2.4ghz systems are much better at ignoring that interference than 72mhz systems were, which is a big reason why gassers have gained so much popularity in the last 10 years. But ignitions can still play havoc with your radio gear, so it's just not smart to run both systems from the same power source without an optical isolator.
