RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Tire Balancer
Old 02-09-2009, 04:37 AM
  #76
Nesal
Default RE: Tire Balancer
So when on the balancer you add the weight to the opposite side of the bottom? right¿
Old 02-09-2009, 05:45 AM
  #77
tommygun32
tommygun32's Avatar
Location: San Diego but living in Dubai, UNITED ARAB EMIRATE
Pretty much like that Nesal. It's like a pendulum. If you sit the tire on the balancer, the heaviest side of the tire is going to automatically swing down and come to a rest at the lowest point. Mark that point and slowly start to add wheight to the opposite side of the inside of your rim. Eventually, where you made that original mark, you sould be able to put the mark at the 12 o'clock position without the tire swinging either way. Then you should be able to put the mark at the 3 o'clock position without any movement and again at the 9 o'clock position without any swing. Once that's done, you should have a balanced tire.
Good luck.
Old 02-09-2009, 07:45 AM
  #78
Jatohulk
Jatohulk's Avatar
ORIGINAL: tommygun32
Good luck.
Good explanation very good..
