Nomadio React 2.4GHz Radio
#376
RE: Nomadio React 2.4GHz Radio
ORIGINAL: vtl1180ny
Has he tried reinstalling the controller and transceiver firmware???
ORIGINAL: MiamizFinest
Well guys this is my first time posting on this topic becuase i have a question the other day a friend asked to me to tune his jato and he had this REACT radioand i must say i loved it.........i was driveing his car around and loved the light weight controler but for some reson at about 100 feet away the radio would loose range and the fail safe would kick in is this normal???? how far is the range suppose to be?? he was kidna pist with his radio and tolled me he wasnt sure if he was going to keep it (he bought it about 2 weeks ago this happen this sunday) i tolled him id give him 100 bucks for it and he sayed hed think about it so lets see what he says...i plan on only useing it for raceing since the only thing i actually race is a mugen truggy............everything else are parking lot bashers running off speketrum and FM with my 3PK radio...........what do u think?? whats the normal range on this radio??? is it faster than the futaba FASST system??
I have no idea since i have no clue about this radio ill ask him next time i see it.........i liked it becuase it was so much more lighter than my 3PK radio and i thought that was a nice feature......ill ask him next time i see him id only use this radio for my one TRACK READY TRUGGY id still my 3PK for all my parking lot bashers since i can use AM,FM,and SPEKTRUM for that radio
46U congrats on ur buy but could u share with us what happen to you REACT??? why did u have to send it back???
Also quick question does the REACT have a backlight??
#377
@MiamizFinest
This link was posted further up in this thread
http://www.rckingdom.co.uk/mam/index...d=214&Itemid=1
There is no backlight
There are pros and cons at bottom.
Nick
Nick
#378
CA
Been trying to order the radio and found the coupon for the free temp sensor but i dont know where the coupon is to get the radio for 229 shipped from carolinas. Is it still around? I'm in college so from 200 to 300 dollars is a big jump for me as I'm trying to buy several things to get started in 1/10 st racing and adding the revo I just got as well.
#379
GA
Sorry looks like you waited to long on for that deal as they are now back up to $259.99 with shipping in the US.
http://www.carolinasrc.com/Webstore/...idproduct=3049
My radio is on its way back from being fixed but will not be home till this weekend. Hope it last more the haf a quart this time!!!!!!
#380
GA
ORIGINAL: vtl1180ny
#381
ORIGINAL: 46u
The steering wheel spring or something broke in less then a quart. I all so listed in on the Nomadio web site and they removed it for obvious reasons. [X(]
ORIGINAL: vtl1180ny
I really hope you get yours back soon. I really like mine. My dad ordered his on Sunday and should have his today, which should make my son happy since he does all the driveing of my Dads Truggy on the track.
#382
I really think that part sucks that they remove ALL support issues from the site would be nice to know what people have had issues with maybe things that we can look out for or be aware of so that maybe others have had the same problems and have fixes that might not require support to get involved.
Ed M.
#383
VA
ORIGINAL: bentgear
If they left them up for folks to see it might make the Spektrum units look too good.
Ed M.
Ed M.
haha...very true....I wished they would leave those posts up there as well, but I doubt they are too worried about spektrum looking too good..I came from spektrum and there is no comparison with the REACT!
#384
Miamizfinest --- Contact [email protected] they'll get You fixed right up with the range issue...
Could be the end of transceiver antenna is kinked over, blocked by metalic chassis/part, TX batts low, software on tx & rx don't match, rx antenna not soldered to the board...
Better yet call Us @ 215-854-8432 just ask for support!
#385
Hi
What is the status of the micro Rx from Nomadio for the React?
What other micro Rx's will work with the React? I only need 2 channels.
Thanks Jeff
Thanks Jeff
#388
Well after all this the guy decided to keep his radio so i will not be geting it.........that sucks........oh well ill just be geting the futaba FASST for my 3PK radio
#389
Does anyone know if the Futaba Fasst sytem will be able to use Spektrum recievers like the Nomadio does ???
#390
GA
ORIGINAL: razzor
#391
NY
ORIGINAL: razzor
Absolutely not... The only reason Nomadio can do it is because it's software based, NONE of the other current systems are... Maybe in the future they will be but I seriously doubt it... Once you buy a Spektrum or Futaba you are stuck using only their receivers...
#392
Why would even a software based TX not be able to send to another brand RX that is not software based? Is there some incryption in play that the TX and RX must share once they are bound together?
#393
ORIGINAL: SAVAGEJIM
#394
NY
ORIGINAL: Damin69
Not really what he is trying to say is that with Futaba and others the programing in the radio is SET to use only thier receivers. Where as with The Nomadio React the programing can be updated with software so that it can be used with other Receivers other than thier own such as Spectrum and Airtronics.
ORIGINAL: SAVAGEJIM
Exactly.... None of the radios have software that can be updated and installed by the user to change any functionality of the radio...
#395
Thats makes Nomadio the only radio to use other brands of recievers , neat
Problem is they dont make a stick radio
#396
my react battery was plugged wrong and placed on the usb to the computer, NOT BY ME, has anyone got this problem fixed????
i kno that the warranty may be void because of this.
#397
GA
Did you turn the radio on with the polarity backwards? If not the radio should be OK. Have you tried plugging it back in properly and see what it does? Electronics do not take kindly to reversed polarity!!!!!! I do not use the USB port for charging I have a jack I plug into the radio and use my peak charger. I all so use a 2600 battery pack.
#398
when i plug it back to the pc the screen comes on an showsthe charging message but when i remove the usb and try to turn on the react nothing happens.
#400
it was pluged into the pc by my aunt and she connected the batts reversed polarity. not to sure if it was turned on. when i plugged it in correctly and connected it to the usb the batt reads 5.19 volts.
