RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
New Project
Old 01-29-2010, 05:01 AM
  #151
troppo
Default RE: New Project
Would of course need an esky attached
Old 01-31-2010, 12:30 AM
  #152
Dirty_Vinylpusher
Dirty_Vinylpusher's Avatar
Ok got a bit done on the coupling for the rear swingarm setup today.
Using some stainless steel fittings a mate got for me a while back and I filed them in the "It'll come in handy" box.
I might try to make this a bit smaller and lighter down the track, but for now it's a good way to work out where things have to go.
Also got the sprocket mounted on the diff, and made some temporary bearing supports for the mock-up stage of the whole thing.
I'll ditch the drive cup setup off the diff, as I'm not doing individual suspension, and replace them with straight axles going to each rear wheel.
Old 01-31-2010, 12:44 AM
  #153
troppo
When it comes to scrounging, modifying or seeing outside the box, you are the chanp mate......
The voices in your head must be running on a permanent caffeine high
Old 01-31-2010, 12:47 AM
  #154
Dirty_Vinylpusher
ORIGINAL: troppo
Hehe yeah...
I guess it's because I've never really had a look inside the box in the first place......
  #155
da mad maori
plumbing fittings?????
your unreal man lol...
way to modify what the diff from??
Old 01-31-2010, 12:49 AM
  #156
Dirty_Vinylpusher
It's an FG diff that DC2MAN sent me.
(Thanks again DC )
Old 01-31-2010, 12:50 AM
  #157
da mad maori
lol nice work...
is not often you here of fg diff blowing so you should have a decent unit there
Old 01-31-2010, 02:31 AM
  #158
Dirty_Vinylpusher
Cool.
Yeah DC reckons they're pretty tough.
I'll still be having a go at making my own though and probably use this diff in the other car.
Old 01-31-2010, 05:05 AM
  #159
dc2 man
Banned
wow dv i like the look of the sprocket on that diff,fairly solid looking set up.
also that suspension set up looks awesome,they look like great a-arms. what way is the weight going so far?
you should get a nice spread of power and good handling from that diff in any aplication you use it on.
man my beetle is very heavy and the engine is 7.5hp plus and i am running "still" the same diff now for the last year,untouched and not even inspected,last time i checked it for greese was when i fitted the elcon balldrive system was over 5months ago.
just a testament to how tough they are.
Old 01-31-2010, 11:58 AM
  #160
Frederik_b
Frederik_b's Avatar
ORIGINAL: Dirty_Vinylpusher
Nice work, thats a very nice looking front end! Do you have a pic of the whole car where we can see the proportions including the engine and rear end ?
That is probably a good thing that the stainless T is heavy (like in heavy duty) as I can imagine there is some stress at this point. That a ingenious setup for the rear suspension, are you planning to use similar shocks setup as in the front ?
Fred
Old 01-31-2010, 03:50 PM
  #161
Dirty_Vinylpusher
ORIGINAL: Frederik_b
Only the ones from the other day before I started on the swingarm mount.
The wheelbase is about 700mm though.
I'll take a couple of pics today.
Old 01-31-2010, 03:54 PM
  #162
Dirty_Vinylpusher
Oh, almost forgot.
Cracked open a couple of laptop batteries last night after watching those "hack" videos on YouTube.
Inside there's 8 nice batteries, a bit bigger than AA's.
One of the laptops hadn't been charged for over a year and each individual battery inside it still held 3.9V! [X(]
Gonna put them on charge and see what they get up to.
Could be a good battery source
Note AA for size comparison.
Old 01-31-2010, 04:28 PM
  #163
QSPSB2
QSPSB2's Avatar
Hmmmm. isn't this the same type of laptop battery that led to all them laptop fires a few years back... lol..lol..
Just joking... I'm sure you will make them work some how
Old 01-31-2010, 04:37 PM
  #164
Dirty_Vinylpusher
Nothing wrong with some fireworks every now and then.
Adds to the effect.
Seriously though, it seems that almost all large batterypacks of any kind contains smaller batteries.
There's a lot of good, cheap sources for powerful and rechargeable batteries out there for us cheapskates.
Just gotta get a voltage regulator of some sort to bring it down to 6V.
Old 02-01-2010, 12:39 AM
  #165
Fabe
Hey DVP, I hope you're planning on using a dedicated charger for lithium chemistry batteries! I've got quite a few of those lying around as well but have never used them. I felt the need for a voltage regulator, voltage cutoff, and explosion hazard next to my gas tank was not worth the extra capacity.
Whatever you do, be careful, because we need to see some more home creations coming from Australia...
Old 02-01-2010, 11:30 PM
  #166
Dirty_Vinylpusher
My sparkie mate takes care of all the electrickery things that are above my head.
And if he can't figure out a way to blow something up, I will....
Right, here's some recent pictures.
Playing around a bit with the pivot point of the rear swingarm.
What do you reckon about shocks at the front of the whole setup, like where the red clamp is in the picture.
Will it work?
Old 02-01-2010, 11:57 PM
  #167
sam123
That looks like an interesting setup you have there. Nice job!
I'm not sure how stiff the shocks you have are, but in the position you have the clamp I think it should work well. If you find that the suspension is too soft, you could always lengthen the part of the beam that extends from underneath the engine a bit.
Old 02-02-2010, 12:50 AM
  #168
Dirty_Vinylpusher
Well I'm gonna have a go at making my own shocks from those gas struts, so I'll be able to adjust/change the stiffness as I please.
Or that's the idea anyway.
Old 02-02-2010, 02:59 AM
  #169
Dirty_Vinylpusher
Just a couple more mock-up shots.
The motor is definitely sitting too high so that will have to be changed.
Found a bearing holder that suits the diff.
Just need something for the sprocket side.
And wheelbase and track width measurments.
A bit too short perhaps.
Aiming for 700mm wheelbase
Old 02-02-2010, 07:18 PM
  #170
Bob-Stormer
Bob-Stormer's Avatar
Will it work?
Work just fine. Be interesting too! Don't over spring it. and if need be, don't be afraid to make the lever arm longer or shorter. Nothing says those rear shocks can't be all the way at the front of the car on a long lever arm if need be.
Old 02-02-2010, 08:32 PM
  #171
Dirty_Vinylpusher
With the twist of the rear swingarm, would it be better to have the shocks angled in any certain direction?
Old 02-02-2010, 10:53 PM
  #172
Dirty_Vinylpusher
ORIGINAL: dc2 man
Dauym!
[X(]
Old 02-03-2010, 01:45 AM
  #173
Dirty_Vinylpusher
Ohkay a couple of photos from this afternoon.
First time with all 4 wheels somewhat attached to the chassis.
Even though it's not supporting its own weight yet, that was a good moment!
Old 02-03-2010, 04:05 PM
  #174
Bob-Stormer
Preferably in the direction of travel. Normally, the rationale for leaning shocks is soften ride, make them more progressive, compensate heavy or light springs to suit the build. etc. a 100 pound spring, at a 45 degree angle, feels like a 50 pound spring. So it's also a tuning thing. The springs only job is to hold up the car and set ride height. Dampening is everything else.
In a perfect scenario, at full suspension extension, the spring reaches zero load at the exact same instance the suspension finishes extending. And is maximally crushed when the suspension is at maximum compression. Or there abouts. It's a trade off.
Old 02-03-2010, 04:20 PM
  #175
Dirty_Vinylpusher
ORIGINAL: Bob-Stormer
Like this?
