RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
New Project
Old 08-16-2010, 02:30 PM
  #251
quarterscalelegends
quarterscalelegends's Avatar
Default RE: New Project
very interesting. nice.
Old 08-16-2010, 04:05 PM
  #252
Dirty_Vinylpusher
Dirty_Vinylpusher's Avatar
Cheers.
The main reason for doing this is because the grinder has a readuction of just over 6:1 so there's no need for further gears or sprocket/chain.
Seems to be a rare breed of grinder as most of the ones I've come across have a 4:1 reduction or thereabouts.
Old 08-26-2010, 04:54 AM
  #253
Dirty_Vinylpusher
Ok here we go.
After days and days and days of trying to construct a decent wheel hub for the rear, I finally almost went nuts....
Lots of good ideas but all too big, heavy and bulky.
That's ok though, I can use some of those ideas on the giant build.
So instead I started working on the rear A-arms.
8mm and 10mm steel rods.
Lots and lots of lathe work involved in making these, and it seemed to be never ending.
Turned out pretty good in the end though.
Still a bit more to do on them, but you get the idea.
Old 08-26-2010, 07:03 AM
  #254
VassilisG
Nice , huge arms.
Did you use an axle before bushing welding , to keep these on the same line ? Did you try to put axles after welding ?
Old 08-26-2010, 07:35 AM
  #255
Dirty_Vinylpusher
Sorry Vassilis, I don't quite understand the question....?
Old 08-26-2010, 07:52 AM
  #256
Dirty_Vinylpusher
Ah I think I know what you mean.
You're talking about these aren't you?
No I lined then up with the end brace and welded them on like that.
I SHOULD have done what you're talking about though and put an axle through them to keep them in line.
Old 08-27-2010, 02:44 AM
  #257
Dirty_Vinylpusher
Rough-in of the hubs and arms.
Seems to work pretty good.
Old 08-27-2010, 06:53 AM
  #258
Lars from Norway
Lars from Norway's Avatar
Oh yes, that looks beefy!
Old 08-27-2010, 07:35 AM
  #259
sam123
This project is coming along quite nicely! Well done DVP.
I love the way you made those hubs [8D]
Old 08-27-2010, 08:05 AM
  #260
Dirty_Vinylpusher
Thanks guys.
It feels like I'm getting somewhere now with this car.
The hubs nearly drove me around the bend.
Days and days and days of building stuff that just didn't work and was too big and heavy and just no good at all.
This seems to work and they're pretty light too.
Old 08-28-2010, 02:22 AM
  #261
Dirty_Vinylpusher
Both sides done, sort of.
Not quite right so gonna have to come off again.
The arms themselves are ok but the mounts are a bit out of whack.
Easily fixed though.
Is it a bit too wide perhaps?
Shouldn't tip over in a hurry anyway.
Old 09-04-2010, 07:10 PM
  #262
Dirty_Vinylpusher
Making the front arms and hubs.
Found some old stainless steel pipe fittings that should work ok as hubs.
Old 09-06-2010, 12:34 AM
  #263
Dirty_Vinylpusher
A couple of mock-up pics.
Pretty wide for its length but it's kinda cool I reckon.
Easy enough to cut it in half and lengthen it a bit if need be.
Old 09-13-2010, 12:42 AM
  #264
Dirty_Vinylpusher
Doing a bit on the front end and started making the steering rods.
Old 09-13-2010, 05:28 AM
  #265
Mudgy
Mudgy's Avatar
you look as though you are maximising your time on the lathe mate. Good job man
Old 09-13-2010, 03:49 PM
  #266
Dirty_Vinylpusher
Yep.
Just about everything gets a spin on the lathe these days it seems.
Old 09-14-2010, 09:25 PM
  #267
Dirty_Vinylpusher
Steering setup coming together.
Old 01-04-2012, 10:23 PM
  #268
tapkoote
Dirty
great build keep it up
I think it was your first build you mentioned bolts vibrating loose.
Any of you guys rode old british bikes, you'll know stuff shakes loose all the time.
Old timer who flat tracked triumphs clued me in to a cheap fix.
After tightening them up, paint with enamel/finger nail polish/carpenters glue.
Some times I just smear silicone sealant.
Tap
