Reload this Page >
New Skymaster 1/6 Su-30SM
Old 05-13-2020, 01:35 AM
  #201
Mikey5547
That’s stunning! I love the paint job. Did it come with the decals on it or did you apply them?
Old 05-13-2020, 03:40 AM
  #202
spaceman 01
My Feedback: (44)
spaceman 01's Avatar
Just beautiful! enjoy it .
Old 05-13-2020, 10:22 AM
  #203
heraldoboldrin
What is your setup and weight?
The CG of the SU27 is difference than the SU30?
Amazing color.. and for me .. better without canard...!!!
When we will have videos....rsrsrs
Old 05-13-2020, 11:58 AM
  #204
vbmab31
its the same CG... the SU30 without canard is the same plane in version MK or MK2, with xanard its version SM.
I wanted to make it very realistic, with a lot of inertia and very powerful weight for slow figures all in powerful. I put 2 Kingtech K260 G4. my goal was to reach 45 kg and it is 45.6 kg on takeoff and 46 kg with smoke cartridges. To increase the weight in a useful way I injected the wing keys, and the rudders of epoxy foam, then I made a lot of reinforcements by distributing the masses at the front and at the rear, to have an effect balanced to make the cobra very realistically and the other figures specific to the SU. I did an F16 identically and its flight is the same as the real one!
For the setup, Jeti CB 400, cortex pro, servos Futaba A700 for elevators connected on cb slots and alimentation on 2 bec of CB400 in 7,0V - others servos are in 6,3v Savox 2290 for flaperons - and slats and rudders hitec 7955TG, Hitec Hsb 8380TH for steering.
For Air system Evojet orbit valves
For lights system Unilight for all lights and afterburner Night Fly
I make important modification for rudder horn in Alu 7075T6 CNC
All fuel system Intairco
Oil Landing gear Silicon 2000 is perfect
this is my setup
Old 05-13-2020, 12:03 PM
  #205
vbmab31
and for the decals its Tailormade decals SU27 CARF 1/6.9 in rub on
And... 500 hours in my workshop lol
Old 05-13-2020, 03:34 PM
  #206
heraldoboldrin
It ia a Lot of weight ...did you fly?
Old 05-13-2020, 08:43 PM
  #207
vbmab31
the weight is voluntary, delta wing or an arrow-shaped wing can be loaded ..
this is my f16 1/6 skymaster 22kg at take off with k210 its perfect and very realistic
Old 05-15-2020, 10:06 AM
  #208
heraldoboldrin
Mine Sukoi Will have...
2 P220
Smoke powwerbox pump
powerbox Royal
Cortex pro gyro for vector
Futaba A700 on elevator
MKS599 on RudderMKS3850 on aileron and slat
MkS 777 for gear
2 GBR high flow UAT
High JMP valve for landing gear
Dual xicoy valve for DoorsDual xicoy valve for canopy
Xicoy valve for brake and speedy brake also
4 4000 2s lipo light and smoke same battery of Turbine as p220 charge the battery
Maybe reduce fuel tanks tô save same weight
Smoke cartriges on wing also
Powerbox maxi wire
Just waiting this amazing plane...
Old 05-17-2020, 09:38 AM
  #209
flyloose
flyloose's Avatar
https://www.instagram.com/p/B9mgw19I...d=d3p9dfjd9p6u
https://www.instagram.com/p/B6yoUFYI...=11a5ex5nc8pdb
Really nice flying....beautiful landing as well
Old 05-28-2020, 07:34 AM
  #210
loryfly
Finally i maidened my su-30MK (without canards)
Wow!! It s incredible!!!!!
Maidened with a frank ft220 plus ft180..... No asimmetric at all.... 100 metres very short runway.... Landed in clean configuration in less than 75 metres.... And with a lot of remaining fuel!!!
I CONFIRM CG IS NOT THE SAME AS SU30 WITH CANARDS... I WAS NOSE HEAVY....MUST CHANGE A BIT AFTER....
vbmab31 (05-28-2020)
Old 05-28-2020, 10:54 PM
  #211
vbmab31
yes he is more rear, have you mesure it?
Old 05-29-2020, 01:07 AM
  #212
loryfly
​​​​​No i just made the maiden flight with the CG exactly on the front spar, then in the afternoon i broke my leg .... So next flight will be in a month at least...
I think 1 cm behind the front spar will be perfect...
Old 05-29-2020, 10:54 PM
  #213
vbmab31
Here is a wing of a SU30 carf without canards.
the red cross represents the approximate CG of the SU30 skymaster with canards.
The green cross is the CG of the carf without canards.
I did my 3rd test flight by removing more than 1KG in the nose and it was pretty good. In back flight i have good sensations. I will redo several flights to validate the CG and have it validated by experienced members of my club, and I will communicate it
but its more than 1 cm behind..
Old 05-31-2020, 04:22 PM
  #214
heraldoboldrin
I think the CG from SU30 and 27 is difference but is Impossible to be tô much...maybe the SU30 hás wromg CG informed in the manual...
Old 06-12-2020, 02:21 AM
  #215
vbmab31
Hello, i confirm the good CG for Su-30 mk without canards or Su-27 :
2cm behind 1st wing key.
with gear down and uat full..
It’s really perfect!
Old 06-15-2020, 01:52 AM
  #216
heraldoboldrin
What you mean wing Key?
Old 06-16-2020, 12:27 AM
  #217
jimibar
2cm behind front wing spar
Old 06-16-2020, 10:29 AM
  #218
vbmab31
yes ! 1st wing spar .. sorry lol
2cm behind the back of wing spar..
Old 07-28-2020, 05:22 AM
  #219
pilot tw
more pictures for Su-30 MMK from Customer
Old 07-28-2020, 05:30 AM
  #220
pilot tw
Su-30 maidened powered by 2 P-220
Old 07-31-2020, 05:11 PM
  #221
pilot tw
New finished color scheme for myself, it will install the 2 x K-210 , Power Box Royal , power bus, MKS 9150HV , 9130HV servos , ^-^
Old 07-31-2020, 09:49 PM
  #222
Mikey5547
Veery nice! Please post video
Old 08-12-2020, 06:53 AM
  #223
pilot tw
Default Skymaster SU-30 in action full thrust vector the way this beast should be flown
Old 08-12-2020, 06:55 AM
  #224
pilot tw
Old 08-13-2020, 06:19 AM
  #225
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Hi
Anyone knows why there is a warning in the manual that indicates that a gyro should not be used in the elevators?
It specifically mentions Powerbox Gyro, but assume the warning is for any gyro in elevators... ?
