Reload this Page >
New Skymaster 1/6 Su-30SM
Old 09-29-2020, 06:25 PM
  #251
pilot tw
the Su-30 CG (with the Canards) before front tube 25-32mm
Old 09-29-2020, 06:27 PM
  #252
pilot tw
and the Su27 CG (without the canards) after front tube 5-12mm
Old 10-01-2020, 05:58 PM
  #253
pilot tw
SU-30 MKII 1/6 scale - Skymaster jets - 52kg Thrust (2xk260g4).
Club: MAB Blagnac (France)
The following 2 users liked this post by pilot tw:
DenisFerrari (10-01-2020), skunkwurk (10-01-2020)
Old 10-01-2020, 06:13 PM
  #254
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
nice jet!
Old 10-01-2020, 06:43 PM
  #255
pilot tw
Old 10-01-2020, 06:44 PM
  #256
pilot tw
Old 10-01-2020, 11:45 PM
  #257
DenisFerrari
su-30 mkii 1/6 scale - skymaster jets - 52kg thrust (2xk260g4).
Club: Mab blagnac (france)
embarassing beautiful!!!​​​​​​​❤
Old 10-08-2020, 12:41 AM
  #258
pilot tw
Hi Anton very nice and stable power jet cat 220👌Ahmed Nasser
Old 10-15-2020, 01:08 AM
  #259
pilot tw
Su-27 maiden with P-220s, and all MKS servos , Power Box Core , Royal .,
Old 10-15-2020, 04:06 AM
  #260
pilot tw
Default Skymaster SU-30 1/6 Scale Twin Turbine Jet Flown by Ali Machinchy
http://www.youtube.com/watch?v=wNwlq...wvKaynIMAax5N4
Old 10-15-2020, 06:39 AM
  #261
mauryr
Old 10-15-2020, 06:40 AM
  #262
mauryr
Originally Posted by leventx
note : this plane have two separate fuel tank than both goes to one 3.5L tank than two line goes out from one tank, this tank connects to UATs ..so when fuel up this plane cant refuel separately need to fuel from two lines together with T fitting... if you put this T fitting close to uat or inside the plane it cause in full speed two uat sucks fuel - air from each other .. for this reason I kept two fuel line from uat to out of plane than outside of the plane I use T fittings to refuel . which its together with my pump ..
Just put a festo valve on each line and problem solved, you can then refuel to both tanks at the same time and also control flow if one fills more than the other
Old 10-15-2020, 06:57 AM
  #263
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
I don't have this jet but my Shockwave has saddle tanks. I keep a hemostat in my box for this purpose, if I see a saddle tank filling a bit faster than the other I just pinch the line and allow the other to catch up. I use small pieces of tygon tubing on the tips of the hemostat in order to protect the tubing in the jet. Works great.
Old 10-16-2020, 11:34 AM
  #264
heraldoboldrin
i had this setup in my MIBO A10, first fill one side.. until you see fuel going out, then fill the other.. in the second tank filling you get the air out first... than the fuel.. and is done.
Easy !!!!!
Old 10-18-2020, 04:54 AM
  #265
pilot tw
Old 10-18-2020, 04:57 AM
  #266
pilot tw
full day of flying Skymaster Su-27 powered by P-220's / Pilot: Ahmed Nasser
Old 10-20-2020, 01:48 AM
  #267
heraldoboldrin
I see a video of a SU30 with smoke system.. what tank they are using on it for smoke?
Old 10-25-2020, 08:00 PM
  #268
pilot tw
we add 2 x 2L tanks for smoke. here are pictures.,
Old 10-25-2020, 08:04 PM
  #269
pilot tw
Old 10-26-2020, 05:27 PM
  #270
pilot tw
Old 10-30-2020, 04:37 PM
  #271
pilot tw
Skymaster SU-27 and SU-30 , Dubai 30 Oct. 2020
Old 10-30-2020, 04:38 PM
  #272
pilot tw
DenisFerrari (11-02-2020)
Old 10-30-2020, 04:53 PM
  #273
pilot tw
Originally Posted by jetspud
A F-15 this size would be awesome
after Su-30 that we has more experanced to do the huge Jets , we now did the very light Su30, so 1/5 F-15 (lentgh 3900mm) in my projects too ,
Old 10-30-2020, 06:06 PM
  #274
pilot tw
http://www.youtube.com/watch?v=51WCI...OrIqfUJea73sGk
Old 10-31-2020, 12:18 AM
  #275
Mikey5547
Thats awesome. What about Tornado?
