Reload this Page >
New Skymaster 1/6 Su-30SM
Old 08-13-2020, 04:50 PM
  #226
heraldoboldrin
If i understand you cabt use only setup.with as X2 for vector amd plane....but i also want tô know the reason
Old 08-15-2020, 06:40 PM
  #227
pilot tw
Last evening here at the Wingham airport, what a great week we had flying and being around close friends.
We had a number of nice jets here, but I must say I was impressed with the way the new Skymaster SU 30 and big Phantom preformed.
Doug Boyle from Jets North was a great help keeping all us equipped with the latest Kingtech engines, JR servos and Skymaster toys.
Old 08-16-2020, 06:23 PM
  #228
pilot tw
Old 08-18-2020, 05:32 PM
  #229
pilot tw
New finished the Su-30 pnp .
CobraJet (09-10-2023)
Old 08-19-2020, 04:23 AM
  #230
Mikey5547
Very nice weathering
Old 08-25-2020, 12:24 AM
  #231
pilot tw
my Su-30MMK pnp almost finish , can not wait to fly it.,
Old 08-25-2020, 12:34 AM
  #232
DenisFerrari
wow...wow...and wow!
Old 09-03-2020, 07:33 PM
  #233
pilot tw
my Su-30 MMK (without the canards) maidened, powered by K-210's ,MKS servos , power box loyal., pnp from Skymaster factory.,
Old 09-03-2020, 10:54 PM
  #234
DenisFerrari
woow, it's fantastic!
Old 09-04-2020, 06:25 AM
  #235
FenderBean
FenderBean's Avatar
Dang it! Every time I see this model it just grows on me!!!!!!
Old 09-04-2020, 05:55 PM
  #236
pilot tw
the Happy customer received the Su-30 pnp too,
Old 09-12-2020, 08:46 PM
  #237
pilot tw
SU-30SM maidened , power by K210's , all MKS servos, power box Royal., pnp from Skymaster factory,
Old 09-12-2020, 08:52 PM
  #238
pilot tw
Happy Customers with Anton flights the SU-30 together,
Old 09-14-2020, 06:01 PM
  #239
pilot tw
Su-30sm awesome flights!
Old 09-22-2020, 05:00 PM
  #240
leventx
Old 09-22-2020, 05:14 PM
  #241
leventx
Yesterday just did maiden for my SKYMASTER SU-30 (no vector thrust).. perfect flying model and great size. From first day received model , I found quality and design is really next level even better than previous SM models. I loaded it with two 22kg turbines which already more than enough power there.. on the grass with full power took off about 50-60m with good speed , 65kg servos on stabs and rest all 45kgs..beatiful model easy to dismantle stabs , fins , wings , back tail …plane is 2.86m when remove nose and that long tail behind canards cant remove so they are 1060m wide … kind of big SUV or family van is ok to transport. I couldn't find anything negative on this plane but many positives … great plane ..
Old 09-22-2020, 05:34 PM
  #242
leventx
Old 09-22-2020, 05:39 PM
  #243
leventx
note : this plane have two separate fuel tank than both goes to one 3.5L tank than two line goes out from one tank, this tank connects to UATs ..so when fuel up this plane cant refuel separately need to fuel from two lines together with T fitting... if you put this T fitting close to uat or inside the plane it cause in full speed two uat sucks fuel - air from each other .. for this reason I kept two fuel line from uat to out of plane than outside of the plane I use T fittings to refuel . which its together with my pump ..
Old 09-23-2020, 12:03 AM
  #244
pilot tw
Congratulations!! Levetx
Old 09-23-2020, 12:25 AM
  #245
leventx
Thanks a lot for this great plane and support for installation
Old 09-24-2020, 07:46 PM
  #246
pilot tw
the Skymaster Su-30 now installing the new K-235G4's , maiden coming soon
Old 09-29-2020, 12:09 PM
  #247
heraldoboldrin
IN the new Manual..
SU 30 CG: AFT FRONT SPAR BY 5 —12 mm
SU 27 CG: AFT FRONT SPAR BY25mm—32mm
After front Spar.. you mean going to the front or to the back of the plane?
Old 09-29-2020, 04:14 PM
  #248
leventx
my SU-30 CG .. on the wing front connection tube and flying good
Old 09-29-2020, 06:08 PM
  #249
pilot tw
Old 09-29-2020, 06:13 PM
  #250
pilot tw
Originally Posted by heraldoboldrin
IN the new Manual..
Sorry, the CG are wrong in manual, we updated the manual now!
the Su-30 CG (with the Canards) before front tube 25-32mm
the Su27 CG (without the canards) after front tube 5-12mm
