Reload this Page >
Jetlegend 1/6 Scale F16
Old 04-06-2014, 12:14 PM
  #451
Ad Clark III
My Feedback: (8)
Ad Clark III's Avatar
Henry,
Here is another option that might work if you plan on cutting the pipe. Its made by Tam and looks pretty cool as well. Good luck
ID:	1984623   Click image for larger version
Old 04-06-2014, 12:23 PM
  #452
andretorres89
andretorres89's Avatar
I would check your locking cylinders to make sure you dont have any leaks. I had leaks on mine and took it to a jewelry to get them redone.
Also i think B1 bob had the same issue with the nose gear not coming down on his and it had something to do with the rod that connects to the nose wheel. make sure its not bent.
Old 04-07-2014, 03:56 AM
  #453
jeff sewell
Hi Jay,
I may be that the over-centre lock is worn/damaged so it doesn't! Though it does need pressure from the cylinder to maintain the lock. If you push it backwards by hand under system pressure, does it fold?
Jeff
Old 04-07-2014, 10:59 AM
  #454
bluescoobydoo
I have done few test tonight at 80 psi and with the air on all the time the gear stays locked only flying it will give me a positive test so I just need to see if my jet tronic valve will give me air with the gear down and I am set.
if it works I will feel relived but stupid as I should have thought of it before now but that's what happens when you don't get to fly it much because of the weather.
many thanks jeff.
how is the yak coming on?
Old 04-07-2014, 12:12 PM
  #455
jeff sewell
Hi Jay,
Correct me if I'm wrong but I think you can shut off the failsafe on the valve so it delivers pressure all the time. Do check if the locking cylinder is bypassing too as Andre suggests - it's a little one and it needs all the help it can get (sounds like my teenage years).
I've finally put the two halves of the Yak together after a lot of work to get to that stage - took all Sunday afternoon to do it too. I've grown used to its' size - doesn't look that big!
Cheers
Jeff
Old 04-07-2014, 12:32 PM
  #456
bluescoobydoo
checked the cylinder for leaks and it seems to be ok I did find a small leak on one of the tee's on the air line an easy fix while the gear is out of the plane. should be back in the air this weekend weather permitting.
Old 04-08-2014, 07:08 AM
  #457
stivvy
many thanks jeff.
I had the same issue with my F16 and bought the Jet Tronics high flow valve (recommended by them).
this valve keeps air pressure when the receiver is off and prevents an undercarriage collapse.
Steve D
Old 04-08-2014, 09:02 AM
  #458
rickj202
My Feedback: (37)
If anyone is interested, I have a the new G2 Jet Legend, BVM F16 brand new in the box that I will listing for sale. It is fully loaded, with nav lights, smoke pump, servos, turbine all installed. Just add your receiver. It is in the Thunderbird paint scheme.
714-342-1040
Rick
Old 04-09-2014, 08:43 AM
  #459
bluescoobydoo
will the high flow valve solve it?
jeff what pressure would you go up to I normally use 100psi, with only 6 flights I can't see it being damaged, do the picture show you anything I cannot see?
ID:	1985541   Click image for larger version
ID:	1985542   Click image for larger version
ID:	1985548   Click image for larger version
ID:	1985549   Click image for larger version
Old 04-09-2014, 12:42 PM
  #460
bluescoobydoo
Old 04-09-2014, 01:14 PM
  #461
jeff sewell
Hi Jay,
I run a UP valve at around 130psi in mine so not sure if the high flow valve would work but, like the other post states, you will always have positive pressure on the cylinder.
I can't see any issues with your locking arm but it may be worth trying another.
Hope this helps...
Jeff
Old 04-10-2014, 05:51 AM
  #462
Henry Chua
Originally Posted by Ad Clark III
Henry,
Thanks Ad....I will keep that I will keep that in mind
Henry
Old 04-12-2015, 10:06 PM
  #463
Scott Douglas
Scott Douglas's Avatar
Location: Hamilton, Scotland & La Roche Bernard, France
Has anyone had any issues with the supplied linkages in the G2 version? As its not supplied with either any kind of instructions or parts list it's all guesswork. As the servos can only go in one way I have one threaded rod that's perfect for the rudder, one that suits the port aileron but the others supplied are way to long to be used on anything. Before I go and make new ones I want to be sure I've got the correct accessory package!
Scott
Old 04-25-2015, 10:31 AM
  #464
Dave Wilshere
Video of JMA member Steve Salmon's F-16 test flight last weekend. Really nice aeroplane. Perfectly powered for scale flying with a P-180Rxi (even in the longest vertical I only just got it to full power!)
Gusty day and no gyros, it handled really well.
Dw
https://www.youtube.com/watch?v=118Wg78ug-A
Old 04-25-2015, 11:03 AM
  #465
bluescoobydoo
very nice, I must get mine out as soon if the weather ever stays good for more than one day
Old 04-27-2015, 11:08 PM
  #466
Scott Douglas
Guys
Does anyone have good pics of their elevator setup.. just want to make sure I'm doing it right as none of the supplied pushrods fit!
Old 04-28-2015, 08:19 AM
  #467
bluescoobydoo
sorry I have looked and I don't have any but I do remember having the same problem
Old 04-29-2015, 12:30 AM
  #468
Scott Douglas
OK thanks mate..I'll feed it a couple of 8911's with ali servo arms, measure and cut new linkages and keep them as short and as straight as possible. Should be ok
Old 04-29-2015, 07:47 AM
  #469
bluescoobydoo
use the closest hole to the centre of the servo for maximum power and you should be fine, I love mine and its one of the last g1 pity we don't get the weather to fly it all year!
Old 11-09-2015, 04:42 AM
  #470
izzy
does anyone have a link to the build manual ?
thanks
Old 11-09-2015, 12:57 PM
  #471
Scott Douglas
PM sent
Old 11-09-2015, 02:16 PM
  #472
John Tancock
I could do with the same?
Old 11-12-2015, 01:28 AM
  #473
Henry Chua
Originally Posted by Scott Douglas
PM sent
Hi Scott,
If you can kindly forward me a copy of the manual that will be much appreciated.
[email protected]
Henry
Old 11-27-2015, 08:11 PM
  #474
Stevef16
G'day Henry. Did you at All receive a manual for this model? Thank you
Old 11-28-2015, 04:35 PM
  #475
Henry Chua
Hi Steve, unfortunately no.
Rgds
Henry
