New Hitec Aurora 9-Channel 2.4Ghz Radio System
#1978
RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
Its a Reichard Proxima II, with 4 servos in the wing, all assign to independent channels. Because of the motor its programed in the acro menu. Until now I have butterfly on a switch (and it works well). I did hope thow, that I could have it on slider, so I could adjust it in flight. Now I only can adjust th flaps on left slider¨.
#1979
My Feedback: (198)
I have to confess that I have REPEATED a pretty significant - and STUPID - "Operator Error" dealing with how the A9 walks you through SELECTING a different model. I have two helis programmed, in position 6 and 7 in the memory. TWICE I have walked through the menus to properly select the desired model, and when I get to the "Select xxxx 'Yes/No'?", I have pressed **NO** twice, thinking it was the alert for the RF "Transmission" buttons.
Both times it has been a disaster, and not without property damage and personal injury. I am absolutely sure that it is my own dumb fault, and confusion interpreting the questions....maybe it's early onset Alzheimers', I don't know.
Regardless, it is a real bummer for me, and the grief of major repairs to two helis, and all the other stuff, well, it has really made me seriously question my own ability to operate a radio.
These were totally STUPID mistakes, the system prompted me as it is designed to do, and it worked flawlessly, it is no ones' fault but mine.
I post this only to serve as a very important safety WARNING- when you are changing models, don't "misread" the "Select model question". It cost me a bunch - TWICE.
#1980
ORIGINAL: Bob Pastorello
I have to confess that I have REPEATED a pretty significant - and STUPID - ''Operator Error'' dealing with how the A9 walks you through SELECTING a different model. I have two helis programmed, in position 6 and 7 in the memory. TWICE I have walked through the menus to properly select the desired model, and when I get to the ''Select xxxx 'Yes/No' ?'', I have pressed **NO** twice, thinking it was the alert for the RF ''Transmission'' buttons.
I post this only to serve as a very important safety WARNING - when you are changing models, don't ''misread'' the ''Select model question''. It cost me a bunch - TWICE.
Don,t be so hard on youre self , I believe I know exactly how you feel , you explained it well . For my part , when I make that , STUPID , mistake , I push an internal , RESET . We,er only human .
Michel
#1981
Bob,
It just happens, been there done that. I had my Stick set up, switched my radio to the Stick , I thought I did. Went and did the walk through, controls looked good but it turns out my Yak and Stick had every thing in common but the throttle. I could not figure for the life of me why the engine would not start. I pulled out the electric starter after flipping wouldn't cut it and BAM! A Saito 72 full throttle into my flight box. I got lucky, all digits accounted for and only broke my prop.
Maybe you can rename one of the Heli to something so different it would be harder to mistake?
The strange thing is, I don't know how I got in this habit but it sounds like a good one. When it asks to transmit I tell it no. I look over the Tx again to make sure I'm ready then hit radio icon to arm the Transmitter then turn on the plane.
Andy
Andy
#1982
My Feedback: (198)
Andy - that is a GREAT suggestion, and may actually make this "fool proof"....you have a great point.If it ain't transmitting, there isn't any way to do what I did. THANKS! I will start making that my habit.
#1984
TX
Hey guys, I know its it here somewhere but I don't know how to find the post about the neck strap adapter balancer hickey. Where can I get one?
Tankengine
Tankengine
#1985
ORIGINAL: tankengine Hey guys, I know its it here somewhere but I don't know how to find the post about the neck strap adapter balancer hickey. Where can I get one? Thanks, Tankengine
as per
Aurora A9, Spectra Pro & Optima - FAQ & Undocumented Features - Mixes, Setups, Tips. {frequently updated}
The nice red alloy Hitec unit, due on USA shelves May 2010,is not only great with neck strap, by grasping the neckof thebalancer with thumb and forefinger,it is also a convenientway ofupliftingTXfrom alaid down position.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
#1986
PA
Hey folks, I am showing off my shinny new A9 just in last thurs....
Well, the r/c buds are curious, so I am basically showing it off and being a propaganda and marketing hand for Hitec, who'd da' thunk'?
So, one gents question is this.. can it do the following (if So, I've sold one for hitec - hey, but wait, where is my commission [] )
Flaperon's? - Mix Elevator to Flaps on a switch?
2 servo'w in the wing
mix up elevator to down flap
mx down elec to up flap
Can he mix this in a switch, so he can turn this mixing on and off by a switch at will?
So I think you state it another way: NOT a Delta mix on channels 1 & 2, BUT Ail & flap of channels 1 & 6 ? (not sure don't quote me, but the elv & flap mix above) ?
Thank you on his behalf
Spreading the wealth R/C style (not obama style... sorry, couldn't resist some good free speech humor )
Cheers
Cheers
#1988
YaHoo!
I sent the 2 rx coupon in the first week of March and got them today. This is great. Now I need to purchase about five more. Hope they come out with a qty deal real soon.
#1989
MI
Andy,
Thanks for the tip;"Turn the transmitter on and choose not to transmit, thenpressing the radio icon to activate the transmit menu."Iwas unaware or missed it in the manual that you could do that. I'd always reset the power to get back to that screen. Works good and I like the idea to do this in practice so as not to accidentally swap models.AndIdid just that on my 6EXa few weeks back.I had my elevator reversed on full power take off. Luckily not too much damage and it was only a ragged trainer. "Sorry about your helicoptersBob." But now transitioning more planes with the availability ofmore receiverstothe Aurora it's something I don't want to do, period.
Today I got my rebate receivers in."What a relief!" Thanks Hitec... It's been a frustrating wait for the radio and then the rebate receivers. It was totally worth it. Ahhhhhh....
Just love this radio so far and am looking forward to setting up more planes in the radio. The only thing I have left to do is the switch mod....
Happy flying...
Happy flying...
#1990
NY
OK folks, I have made a searchable pdf version of the Aurora 9 manual. I don't know how to post or upload files here but I did send it to HitecRCD support so maybe they will post it on their web site.
Makes finding things a simple 1 second task.
Jim D
By the way, I made it with a trial version of Aquaforest Autobahn DX 2.2 software which you can download from the web. Once you install it you can use the function OCR IMAGE ONLY PDF. to take the HitecRCD manual pdf download and convert it. Save it with a new file name though.
Jim D
#1991
My Feedback: (24)
TN
Mike, I have a suggestion or question can one of the Timer functionsbe madeso that the timer is retentiveholds its value even though the radio is turned off for each model so we have a way of knowing how much time we have on a specific model.
#1992
My Feedback: (13)
MN
ORIGINAL: craigteffe
Mike, I have a suggestion or question can one of the Timer functions be made so that the timer is retentiveholds its value even though the radio is turned off for each model so we have a way of knowing how much time we have on a specific model.
Greg
#1993
ORIGINAL: OldRookie
I like this one.
Greg
Greg
Me TWO, ................................. put it in the wish list . I think this is a great idea .
Michel
#1995
ORIGINAL: JIMF14D
My planes usually go to RC heaven before I go beyond counting on my finges and toes.....
Michel
#1998
ORIGINAL: PLANE JIM
what does ''OV'' mean-this is what is on the display of Aurora in another forum-thanks
Go to an official Hitec sponsored forum and ask. The we will find out!
#1999
ORIGINAL: JIMF14D
Jim D
Jim D
#2000
NY
Itried to upload searchable manual here but it is too big (49MB) I guess. It times out after a minute or two......
