Reload this Page >
TA 152H Meister Scale Project Grun 4
Old 04-24-2015, 01:14 PM
  #1126
pandissix
My Feedback: (134)
pandissix's Avatar
If I had only one source to go to for accurate TA152 info photos and proper scheme it would be Hitchcock book.
ID:	2091631   Click image for larger version
Old 04-24-2015, 01:17 PM
  #1127
vertical grimmace
vertical grimmace's Avatar
Flitemetal would be a good option for bare metal items such as the bottom of the wing. On the model I am doing, V30-U1 prototype, it has a bare metal section in the fuselage. That extension area in front of the tail. I used flitemetal here. Also around my canopy frame etc. I plan to "burn through" my colors to expose some bare metal that way. I will also be painting some areas silver before the color, and burning through to that for weathering.
ID:	2091633   Click image for larger version
ID:	2091634   Click image for larger version
ID:	2091635   Click image for larger version
ID:	2091636   Click image for larger version
Old 04-24-2015, 01:24 PM
  #1128
vertical grimmace
Funny, I think that is the only one I do not have! As far as the model I am doing, I have all that I need, but I am sure I will pick up the Hitchcock boof eventually. I really love the book here. It has tons of details of Green 4. http://www.zoukeimura.co.jp/en/produ...ml#conceptnote
It is great we all are getting our TA 152 done this year. Fliteskin has his, Invertmast with the blown up Andersen, I have a 1/5th Andersen, and yours in 1/4 scale.
Old 05-01-2015, 03:53 PM
  #1129
invertmast
My Feedback: (23)
invertmast's Avatar
Looking good guys!
Re. The bare metal wing. Other than Green 9, i have seen nor read any documentation to suggest that any part of the bottom of the wing of Ta152H's were to be left bare. Ive got 4 books on the 152 and have at one point read all of them cover to cover.
Since i hope to have my prototype all composite model ready for 12o'clock high in Sept/Oct, i need to figure this stuff out as i dont have much time considering i have had to redesign the entire wing and build/detail/mold it still.
Old 05-01-2015, 04:11 PM
  #1130
pandissix
My Feedback: (134)
pandissix's Avatar
Well Thomas ..Todd and I kicked this around a lot. It was a mutual decision to go with something different than the typical RLM 76 finish every other guy does. I wanted this to be unique and really showcase Todds master ability at painting at this level. One can argue that at this stage of the war paint is and was scarce and this is well documented in numerous sources. So with some artistic discretion we decided on this.
Old 05-01-2015, 04:15 PM
  #1131
pandissix
My Feedback: (134)
pandissix's Avatar
I won't be going to Top Gun although I think this would hold its own at any level for pro am or team entry. I like to do things different and push the limits of Luftwaffe birds ( for example the first guy to go electric twin on a 40 pound ME262 eight years ago) and one of the first to go 1/4 scale on a TA152 so charting new territory once again.
  #1132
vertical grimmace
So Invert, Are you going to do a hollow molded wing wing like we see with the high performance pylon racers, and gliders? Many of those molds I have seen were CNC machined out of aluminum. Quite a task I would imagine.
I would have to assume that whether the panels were painted, or left bare metal, the lines and rivet details would remain the same. It would just be up to the modeler to decide how they wanted to finish it. Considering the majority of the documentation shows it painted, any competition aircraft would most likely opt for the RLM 76 finish.
Old 05-01-2015, 04:17 PM
  #1133
pandissix
My Feedback: (134)
pandissix's Avatar
And did I mention this is going to be electric. I don't think anyone has attempted this plane in this scale electric.
Old 05-01-2015, 04:22 PM
  #1134
vertical grimmace
That is a big electric. Looking forward to the flight videos.
Old 05-01-2015, 04:25 PM
  #1135
invertmast
My Feedback: (23)
invertmast's Avatar
Yep,
it'll be hollow molded, except all the detail will be in the molds just like how i have done with all the fuselage parts. The main reason for the wing redesign was to push the wing tube aft 2" to make room for my scale landing gear and to put the Te kink in the proper position. As built, the Te kink is 23" to far inboard at my scale.
Old 05-01-2015, 04:28 PM
  #1136
invertmast
My Feedback: (23)
invertmast's Avatar
oh i know and wasnt trying to say you guys were wrong in doing so, its your model and your choice in how to do it. Plus i fully agree with your artistic licensing. Fortunately (and unfortunately for the competition guys), the lack of documentation on late war aircraft is both helpful and a hinderance.
This being electric will be very impressive! Mine personally will be powered by a Kolm IL135 with a gear reduction and a custom 3 bladed Siedel props scale VS9 prop.
Old 05-01-2015, 04:49 PM
  #1137
pandissix
My Feedback: (134)
pandissix's Avatar
Thomas your a master at what you do. From your Horten to the TA152 it's true art.
I am curious if your parts will be interchangeable with mine? Like a canopy or cowel? It mine are based off Meister scale parts would yours be plug and play?
Old 05-01-2015, 04:51 PM
  #1138
t_burley
My Feedback: (59)
not speaking for Thomas here Rich, but I doubt his parts would
work although he has killer parts.
Thomas' is scaled up, updated Anderson plans
Old 05-01-2015, 04:52 PM
  #1139
t_burley
My Feedback: (59)
ETA...........not to say they couldnt be modified to fit however
Old 05-01-2015, 07:05 PM
  #1140
invertmast
My Feedback: (23)
invertmast's Avatar
Pandi,
thanks man! I really try hard to make each subseqeunt model better than the previous. I have aspirations to do another (#3) HO-229 but fully composite and utilizing a different layup to try and shave 9-12lbs off the model. I believe doing that would make it much nicer and easier to fly (flying was easy, takeoffs were a pain in the butt @30lbs).
not sureon my parts.. My cowl is 11 1/4 or 1/2" in diameter and about 8-9" long, the top where the fixed vent panel is drawn from factory drawings and 100% accurate, this may be the only area that doesnt match up to your fuse.
My canopy on the other hand is completely different than anything on the market currently. I used factory FW TA152H drawings for the profile and cross sections of it. That said, it is the same forward size/shape as a FW190 and the rear fairing is the same as a 190, so they may fit..
everything else, probably not, then again i dont think youd want composite wings/stabs for yours
Old 05-01-2015, 07:14 PM
  #1141
invertmast
My Feedback: (23)
invertmast's Avatar
Very true on the "updated" part. Haha
ive changed the vertical fin, rudder, stabs, elevators, wing (only the airfoil is unchanged), gun hood, cowling, belly pan, wing fillets; supercharger/cockpi scoop, canopy, canopy fairing and a whole bunch more.
Whenever i start with someone elses plans i always end up correcting a Lot of scale deficiencies (in andersons defense, alot of the documentation i have wasnt around and/or readily available when he drew up the original plans). The only thing that wasnt changed much is the wing airfoil and fuselage cross sections/outline (they are nearly spot on), but once its all composite, its basically going to be "my" model as there will really be very little in common with enlarged plans.
and then there is the completely scale landing gear struts that has all the up lock flanges, gear door bosses, etc cnc machined out of a solid block of aluminum.
Old 05-02-2015, 03:18 PM
  #1142
vertical grimmace
One of the nice things about the TA 152 over the FW 190 variants is the scale location of the aileron linkage. It is in a better position from a mechanical/geometry stand point. Being that the TA 152/s is located at the center of the surface, and the FW 190 is right there on the very end.
Old 05-02-2015, 05:04 PM
  #1143
pandissix
My Feedback: (134)
pandissix's Avatar
Ok so here is some stencils going down. In another effort to keep this unique twist on Grun 4 Todd is laying down some overspray effects on the letters.
ID:	2093608   Click image for larger version
ID:	2093609   Click image for larger version
ID:	2093610   Click image for larger version
ID:	2093611   Click image for larger version
Old 05-02-2015, 05:14 PM
  #1144
pandissix
My Feedback: (134)
pandissix's Avatar
Some interesting photos of Grun 4 post capture and with allied applied FE number. Notice fading oversprayed letters
ID:	2093613   Click image for larger version
Old 05-02-2015, 05:17 PM
  #1145
t_burley
My Feedback: (59)
glad we didnt do that paint scheme LoL
Old 05-02-2015, 05:29 PM
  #1146
pandissix
My Feedback: (134)
pandissix's Avatar
Poor Grun 4 here looking FUGLY. But would start a few conversations on the crazy markings and traces of it original.
Old 05-02-2015, 05:32 PM
  #1147
t_burley
My Feedback: (59)
true, and I dig the tagged look, and thats why I, and you like
obscure schemes.
we could just finish Green 4 here, send it to East LA for a weekend and
let them tag it down there, might be interesting :-)
Old 05-02-2015, 06:39 PM
  #1148
vertical grimmace
Of interesting note, this aircraft saw a little combat, and has confirmed kills. It is a good subject to be sure. Good that you guys are preserving it to a better time of it's career! : )
Old 05-02-2015, 06:49 PM
  #1149
invertmast
My Feedback: (23)
invertmast's Avatar
I have actually been thinking of torturing myself by doing the post war scheme. The only problem would be color and markings for competition.
Old 05-02-2015, 06:54 PM
  #1150
vertical grimmace
Not sure about the top and bottom view (for the wings), but the Monogram publication is a great reference for that scheme.
