ESM FW D-9
#1076
RE: ESM FW D-9
Cool, thanks for the tips.
Hey Ram, I ordered some on Monday. I got the dummy static prop as well. Damn exchange rate is a killer. I am also talking with Phil about his muffler for the G-62. This is the engine going in the TA 152. It can be completely concealed and add a bunch of power as it is a can. More power is always better!
Those Sierra gear are so awesome. I was wrong about the angles though. They do retract to like 85 or so. It just did not look like it until I could cycle them. Man, they work really smooth.
#1078
RE: ESM FW D-9
ORIGINAL: Ramstein44
Hey Vertical,
Just letting you know that I recieved the exaust stacks yesterday. They shipped out from Fighteraces last monday.
Hey Vertical,
I got them as well for my Ta152 build (on RCSB).
They are really nice and worth the money
#1079
RE: ESM FW D-9
Hi guys,
Just a quick question to Kel and the others;
What did you guys set as downward and right thrust any specific values or you pretty mutch leave it in the axis?
Cheers,
Lio
Cheers,
Lio
#1080
My Feedback: (157)
RE: ESM FW D-9
I built it per the manual.
Attempted to get a few more flights in at Chattfield early this morning, got it ready to go and stopped to work on my friends Bird dog so he could maiden his. Winds were aporx 9mph.. Just as I started to taxi out, the winds started to gust up to 37mph.[X(] and were continous! Oh well... another day.[&o]
Sad thing about the whole event is that my friend stepped on his horizontal stab taking the wing apart[:@]...Guess he'll have something to entertain him tonight
#1081
RE: ESM FW D-9
Folks, maybe you can help me.
I have problems starting the XYZ.
What have I done;
-I have replaced the original ignition with RcExcl
-I have replaced the carburator with one from a G-38 that runs fine.
But still, the same happens;
-I inject fuel directly into the carb first, just to be sure
(The fuel line is a bit long to the tank.....)
-I have nice sparks from both plugs.
-I can see explosions in the cylinders (exhausts are off)
-It fires 2-3 revolutions, then stops.
-I can see the fule line is filled with fuel after these 2-3 rev ignitions.
I am sure the hole for the pump is aligned even through the gasket, so the pump should be okay.
But it does not want to run......
Compression should be ok, because my electric starter, which turns my Saito G-57,
isnt strong enough to turn this one.
Does any of yours have gaskets between the cylinders and the crankcase? Mine does not.
(So I had this crazy idea; Maybe it is missing the gasket between cylinder and crankcase....
the compression would then be higher than others.....)
I found a gasket for XYZ 26cc here...I wonder...could it be that the XYZ 53cc has two of these cylinders...
http://store.octopusrc.com/XYZ-26A-Gaskets
It is a cute little engine, shame I cant get it to run.
What have I done;
#1082
My Feedback: (8)
RE: ESM FW D-9
#1083
RE: ESM FW D-9
ORIGINAL: kwik
Just to cover all bases: I guess you have you tried starting it with mufflers/canisters mounted? Does the same thing happen then?
#1084
RE: ESM FW D-9
ORIGINAL: n8622t
sorry Ram, I have been grounded for the entire week with high winds or rain[&o] Good excuse for staying inside and finishing a build
Same here on the other side of the world! Was due to go out today with my flying buddy,but was away for the weekend and only flew back in this afternoon. By the time I got home, the winds were up to 20kts.[:@] I might pop out mid week if the weather is fine butwere away next weekend again
Kwik,
If you have replaced the ignition and the carb and it still doing the same thing then it would be fair to rule them out as the problem items. I would install the originals again. Have you checked the timing?
Try richen in up the needles as well, if you have to run the needles more than say 3 turns out then I would start looking at the fact that you may be sucking in air somewhere and look at the gaskets. If the gasket that goes inbetween the two crankcase halves is leaking then the pump side of the carb will not get pulses strong enough to draw the fuel through which may be your issue, but I would try and start with the easy/non-invasive options first.
Keep us posted on how you get on with the engine.
dave
#1085
RE: ESM FW D-9
p47pilot;
On this engine it isnt even a muffler; It is a flame-damper. hehe.
(But I might try to put the two units on, just in case...but it shouldnt have anything to say, logically...)
Dave, thank you for your advice;
-I set timing to 30 deg. It was 40 deg. Maybe I should go back to 40....
-I will follow up on gaskets and air-leaks on fuel lines. So, could you please have a look;
Is it a gasket between cylinders and crank-case on yours?
It isnt on mine. Here is the XYZ 26cc gasket;
#1086
RE: ESM FW D-9
I test-fitted the cockpit, still haven't painted anything or added any ofthe scale details, but already at this stage this kit brings the model to life. As far as the Sierras are concerned, they areworks of art. (Still waiting for the Sierra airkit).
#1087
RE: ESM FW D-9
ORIGINAL: kwik
p47pilot;
p47pilot;
Kwik,
I have a gasket in beetween each cylinder, they look like the ones you posted.
I have spent 3 frustrating days at Stow Maries WW1 field trying to get the 190 reaqdy for flight. Everything checks out fine but glitches are soooo bad it won't even run on it's own. I need to trace the problem and go try it again.
On the plus side I did get a go on the ESM/YT Raiden, with a Z62 crammed in the nose - ACE!!
Muds
#1089
RE: ESM FW D-9
ORIGINAL: STICK MODE
What are you running it on muds 2.4 or other ?
Spectrum 9 channel RX (one of the new DSMX things) and a JR DSX9 tx.
Further investigation needs to be done, but we ran it without the wings on and it easily made the 30m range test, but when the wings were fitted not even a metre away and it glitched itself silly.
Muds
#1090
RE: ESM FW D-9
ORIGINAL: kwik
p47pilot;
p47pilot;
#1091
RE: ESM FW D-9
ORIGINAL: kwik
p47pilot;
p47pilot;
Yes My engine also has the gasket inbetween the cylinder and the crackcase. on both of them!
I would leave the timing at 28-30 if you are confident that you have set it correctly. I would recommmend that you put the original carb back on though.
dave
#1093
RE: ESM FW D-9
Hey P47 Pilot,
Here are some links to places that sell the Fw190 wheels. Mine are the sierra/fliteskin/fighteraces ones. They are all the same and to be honest, I think they are made by Glennis anyway!
http://www.sierragiant.com/products.html
http://www.fliteskin.com/FwAcces.htm
http://www.glennis.com/germanwarbirdgallery.htm
http://www.fighteraces.co.uk/
The wind's have been at a constant 15-20kts all week so far[:'(] I might wake up real early tomorrow to beat the wind and have a fly before work.
dave
dave
#1094
My Feedback: (157)
RE: ESM FW D-9
Mine are glennis and are completely different from the others! Glennis wheels are above them all but you'll pay for them! Glennis wheels also have the best details!
For the money, I'd go with SIST if you want nice details, but truth be told... With a little hard work[:'(] Williams brothers wheels can be truly scaled out. I've seen some really nice detail done to them! And their a lot cheaper then the ones we mention!
#1096
RE: ESM FW D-9
ORIGINAL: mudflap31
Muds
Muds
Muds
#1099
RE: ESM FW D-9
Hey Mud, ddi you end up sorting out your glitching issues?
I have just come back form the field after another 3 flights on the Dora. The wind was starting to pick up towards the end, but I at least got a chance to fly with the 22x8 prop on it. I wasn't really all that impressed by it. the engine was burbuling as carrying on a little so that wasn't helping. I need to re-tune it for the smaller pitched prop. I stuck the 22x10 back on it because it was quicker that pulling the cowl off to adjust the carb and had two flights with that on and she went very nicely.
I also have come to the conclusion that the throw rates in the manual are too sensitive for the elevator. even the ailerons can use some dulling down. Also am starting to gather some data around mah useage with all the digital servos, and I have to say is that I am mightily impressed with it so far. I had 2 flights previously about 6-7mins long each, including range testing etc and it only used 170mah per pack. I've had 3 flights today and will check to see the mah used but 80-90mah per flight per pack means that I could get about 26 flights in before they are flat!! and that's the draw taking into accound that she has 8 digital servos installed. I could fly all weekend without having to worry about charging the packs. The ignition pulled about 300mah for the 2 flights.
I was going to get some more shots of her flying but I left the camera at home Next week should be the appointment with the HD video camera One thing that I have to address is the lack of a pilot in the cockpit! it's really starting to bug me now Ty's cockpit kit was shipped out about a week ago so it should be turning up next week some time.
dave
P.s. In regards to the wheels, I will defer all comments in favour of Ram's extensive experience for an accurate reply, other than to say, try giving Darrly a call at sierra. I believe he has them, just not listed on the website.
dave
#1100
RE: ESM FW D-9
ORIGINAL: ticketec
dave
dave
Hi Dave,
I have managed to remove 1 12" extension lead from each aileron, but cannot run the engine untill the weekend, it's dark when I get home from work [:'(] On Saturday I intend to range check it while running the engine in the fuz, then, if all is ok put the wing on and unplug one item at a time to try and find the culprit (this is assuming there is a bad connection somewhere). If this does not work I will try another new RX. This is the first model I have used a DSMX rx with, I can't seem to get a DSM2 these days. I#m wondering if my DXS9 doesn't like them [&:]
I'd be interested to know your throws and amounts of expo if any??
Cheers
Muds
