Jp 4
Old 08-01-2016, 01:20 PM
manchu9inf
Default Tamiya JagdPanzer IV
Was delivered today!!
it may be this version with Zimm. Will have to decide!
or maybe something like this with Zimm
Name:	JP4 in box 0.JPG
ID:	2175430   Click image for larger version
Name:	JP4 in box 1.JPG
ID:	2175431   Click image for larger version
Name:	JP4 in box 2.JPG
ID:	2175432   Click image for larger version
Name:	jagdpanzer_iv_l_48___panzerjager_lehr_abt___panzer_lehr_division__normandy__july_1944.jpg
ID:	2175433   Click image for larger version
Old 08-01-2016, 01:33 PM
TheBennyB
Looks cool Will, you gonna go with the steel wheels on the first positons?
Old 08-01-2016, 01:39 PM
ausf
ausf's Avatar
Ah, the suitcase of goodness.
Old 08-01-2016, 03:13 PM
manchu9inf
No steel wheels, its going to be the L48 not the L70 gun. Already have the shorter barrel and muzzle brake for it.
Old 08-02-2016, 05:00 AM
Panther F
Panther F's Avatar
Nice score!
I'm with you... the L48 is starting to look better and better to me. Plus it's easier on the battlefield items too, huh.
Jeff
Old 08-02-2016, 07:39 AM
tch2000
omg. Awesome. Post build reports!!
Old 08-02-2016, 03:32 PM
manchu9inf
build pics will be coming, Already getting a sleeve made for the smaller barrel and getting primer on some parts now.
Old 08-02-2016, 04:08 PM
Pcomm1.v2
Pcomm1.v2's Avatar
Awesome, did you make the shorter barrel?
Old 08-02-2016, 05:26 PM
manchu9inf
No, i had an extra Tamiya panzer IV barrel and muzzle brake. but the the L70 barrel has a greater diameter than the L48 and to convert will require a sleeve.
Old 08-02-2016, 07:31 PM
manchu9inf
here is a pic of the decal sheet and the clear parts for the periscopes. pretty cool there is a decal for the fire extinguisher!
Name:	JP4 decals and periscopes.JPG
Old 08-02-2016, 09:10 PM
Pcomm1.v2
Pcomm1.v2's Avatar
Hi,
Really nice detail photos! Thank you for the tip for the L48 barrel and muzzle brake (one metal barrel plus the RC B Parts, need
2 B Parts plastic trees to make one muzzle brake).
AAF Museum has the parts, just checked and see the parts list below, for anyone else interested. Think I will keep the L70 gun though and center up two return rollers and delete the 4th rollers, because the late Lang's only had 3 return rollers on each side. Thus, I can then eliminate having to do Zimmerit and have an Ardennes Offensive Lang in ambush camouflage.
Another question, are the Tamiya Pz4J metal idlers similar or look close enough to the Lang's plastic idlers? I included the Tamiya Pz4 idler parts set in the parts list below, A & B wheel set, axle shafts bag, bushing bag and idler assembly screws, in case they might work?
Should have my kit Friday, hoorah!
John
ID:	2175615   Click image for larger version
Old 08-03-2016, 05:04 AM
Panther F
Panther F's Avatar
Dang it guys! I might have to get it after seeing all of this.
The sliding/pivoting armor cover for the hull MG is a nice touch!
Jeff
Old 08-03-2016, 05:31 AM
TheBennyB
Will, what exhaust did they do on this kit? If anyone is looking to do a late 3 return roller chassis you may also want to change exhaust from the large single muffler to the dual.
http://www.rcuniverse.com/forum/rc-t...l#post10863546
Old 08-03-2016, 02:00 PM
manchu9inf
the exhaust is the same as the panzer IV. what is cool, is the fire extinguisher is the on/off switch.
Old 08-03-2016, 04:51 PM
manchu9inf
Default JP4 Idler
Good news, the rear idler will take bearings. While it is plastic, i think it will work well even with metal tracks.
Name:	JP4 rear idler (6).JPG
ID:	2175672   Click image for larger version
Name:	JP4 rear idler (2).JPG
ID:	2175673   Click image for larger version
Name:	JP4 rear idler (1).JPG
Old 08-04-2016, 03:04 PM
philipat
Does it come with those bearings or did you have to get them separately?
Old 08-04-2016, 03:07 PM
manchu9inf
I had the bearings, the kit comes with bushings. those are the bearings that fit the sherman, i dont have the size off the top of my head.
Old 08-04-2016, 07:54 PM
manchu9inf
Well, the rear hull plate is just about done, the zimmerit is on it, stock bolts replaced with hex head bolts, tow hitch drilled out and pin installed. the muffler is not glued in place as it will need to get painted and weathered separately. Currently working on applying zimm to the front glacis plate.
Name:	JP4 rear hull (1).JPG
ID:	2175833   Click image for larger version
Name:	JP4 rear hull (2).JPG
Old 08-04-2016, 08:09 PM
TheBennyB
Real nice Will! Nice job on the zim and not getting lazy on us and using the supplied sheets. Always admired your zim skills.
Trying to have her battle ready for the Sept. event?
Old 08-04-2016, 09:40 PM
manchu9inf
the goal is to have it ready for September! but there is a lot of area left to zimm! And the gun mantlet is off at Daryl's getting worked to accept the short L48 barrel. Waiting on the Speed 400 motors to come in, convert all connections to Deans, and mount metal tracks. I will do a list of all mods soon.
Old 08-05-2016, 04:49 AM
TheBennyB
Right on, will be interested in seeing how the plastic idlers handle the metal tracks after a few battle weekends.
Old 08-05-2016, 05:21 PM
manchu9inf
i think they are going to hold up, you can't get super tight tension on the panzer IV chassis which shouldn't put a lot of strain on them and with bearings mounted they spin very easily, and finally the metal Panzer IV tracks aren't heavy. My bet is they will hold up fine.
Old 08-05-2016, 08:02 PM
Crius
Thank you very much for doing this thread. I'll be getting the summer bonus check soon and I'm really trying to get one of these. I'm watching very closely and taking notes. I'm hoping you'll test both plastic and metal tracks and give your observations of the differences in performance, maybe even with video. Still a ways to go to get to that point, eh?
Is it OK if I call you Will? You can call me Gary or Max or even Will, as that's one of my nicknames, being the first four letters of my last name.
I'm looking forward to photos of that on/off switch. Sounds pretty cool. And is there an option for a variant without the zim?
Old 08-05-2016, 09:01 PM
manchu9inf
Some work was done on the lower hull, the zimmerit is looking pretty good,just need to the weather to cooperate and get some more primer on the suspension parts.
Gary, there are other version you can do without the zimmerit, this is going to be an earlier version with the shorter 75mm L48 gun built before AUG 44. if you are wanting to build the version with the long barrel L70 gun you can easily build it without the zimmerit.
Name:	glacis plate.JPG
ID:	2175913   Click image for larger version
Name:	front hull 2.JPG
ID:	2175914   Click image for larger version
Old 08-05-2016, 09:37 PM
Crius
Thank you. I'm planning an out-of-the-box-build, with whatever upgrades (like the bearings) that will improve performance and/or durability while still staying a primarily stock tank. I'll probably run it on a 6 channel radio, possibly the TGY i6, mainly because I don't have a four channel radio. Of course, I'm doing a lot of planning for a guy that still hasn't nailed down the funding.
