1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
problem :-/
Old 09-24-2006 | 01:19 PM
Default problem :-/
i noticed when i was driving and i hit my break, the front right tire did not stop, it just slowed down realllllly slow (almost like the "break" wasnt working), so i was going to take off the tire to try to see whats wrong, and now i cant get the tire off lol, i took tires off before ut this one, the dogbone is spinning when i turn the nut, what should i do?
Old 09-24-2006 | 01:22 PM
Jrgunn5150's Avatar
Default RE: problem :-/
Sound's like you rounded the hex, or didn't get it back onto the drivepin. Grab the dogbone with needle nose plier's and pull the nut to investigate.
Old 09-24-2006 | 01:32 PM
my needle nose pliers cant even grip the dog bones, it just scratches them, and i dont want to break them
Old 09-24-2006 | 01:43 PM
My Feedback: (325)
Hold the opposite tire and the drive while loosening nut.
Old 09-24-2006 | 01:46 PM
same thing, the dog bone is still just turning with my pliers
Seek and Destroy's Avatar
Or the spring cam out. If the spring didn't come out, the dogbone broke, or the wheel got rounded off. I bet it was the spring or wheel.
Old 09-24-2006 | 01:49 PM
My Feedback: (325)
Can something be wedged into the outdrive? Something must be stripped/slipping inside drive if the dogbone is still turning. Anyways maybe a few more hands and hold tire/wheel at a bind, hold dogbone with serated pliers and then another hand on the nut?
Old 09-24-2006 | 01:51 PM
THis is why I like cvds, much easier to take the wheel off.
Old 09-24-2006 | 01:55 PM
damn, atleast i got it off but there is no little metal pin, its like really small [>:]
Old 09-24-2006 | 02:16 PM
You need the little pin. Unless you really crank it on there, you need the pin.
Old 09-24-2006 | 02:24 PM
ya, my mom is going to the hobby shop tommorow after work to pick me up some, hopefully they got them ^^
Old 09-24-2006 | 04:02 PM
Jrgunn5150's Avatar
I forgot about the spring, I love cvd's!
