my unique micro-t on steeeeeeeeeeriods :)
NY
my 10250kv, mambafied, 15c 250mah lipo'd, ultra custom midmotor mounted micro-dt
Check out the insane center of gravity..... nothing is higher then the tires....... 35+ mph...... insane handling...... super durable...... many of my own custom designs....... many in the process of being manufactured!!
hope you guys like the pics if you havnt seen them elsewhere. all comments welcome
Heath
Heath
RE: my unique micro-t on steeeeeeeeeeriods :)
I can see tiny little thumbnail pics, but not enough to get the micro-t goodness up close. Post better pics if you can.
Oh, and by the way you are INSANE!
NY
sorry guys.....
should be around 10 pics of the bodies and all the custom chassis and electronics as well
Insane? me? hahahaha thanks
NY
thanks guys! i thought i would post the parts listings and stuff so here goes
Losi 10250kv bl motor with 2 eflight tail rotor heatsinks
Mamba 25 esc rewired for micro use with ae heatsink
15c 250mah micron heli battery with micro deans
Jr sm22 micro servo and saver
Spektrum sr3500 micro reciever with my own custum lexan hideaway antenna
Losi front and rear aluminum pivot blocks
Losi front aluminum spindles
Atomic ceramic bearings
Walkera 5-5 ball links and studs with 3racing titanium rods (killer combo in my opinion, modified steering block) can you say ZERO slop???? i can
RPM front bumper
raminator tires
my own custom hideaway lexan antenna
My own custum made m18 rear foams mated to micro-t hubs.... 30mm of pure traction!!! 50 batts and no chunking either they look brand new!!
My own design... custom 2mm thick 2mm weave carbon fiber midmotor extended wheelbase chassis (10mm ext.)
my own custom made .5 mm graphite stiffening rods utilizing 3 racing ball studs and caps.... this thing has ZERO flex.... AND i mean zero yet the chassis is extremely light!!!
Heath
RPM front bumper
raminator tires
Heath
NY
if you consider a few hundred made by machine at a time.... yes
I dont want to make myself unwelcome to any of the mods here so if anyone would like some details please email me at [email protected] i will foward you the press release as well as add you too my mailing list so you can be informed as things progress! i have alot of interesting things coming over the next few months. thanks for asking!! and thanks for the kind words
Heath
Heath
