Cheap 1/2A starter
Cheap 1/2A starter
Here's a pic of a little 1/2A starter I made with stuff laying around the hobby room.
Materials:
Old R/C Car motor - 05
Door Bell button
Heavy duty Paint stick
Tamiya connetor
Some fiber tape and Silicone glue...
Prop adapter
9/16 socket and some silicone tubing (insert)
Power comes from a little 5 cell 1700 mah pack
Works like a charm!!!...
Full sized image here - http://www.crazyherb.com/CheapDelta/halfAstarter.jpg
Email or reply with any questions/comments!
Enjoy!
CrazyHerb
Materials:
Door Bell button
Tamiya connetor
Prop adapter
Enjoy!
CrazyHerb
TN
RE: Cheap 1/2A starter
I made mine last year from an old dustbuster motor and a 1500 mha 6 cell r/c car battery. The driver is a foam paint brush handle drilled and epoxied to the motor shaft and a section of 3/8 inch hose on the end. It works great!
Ya....that's cool....good idea....dustbuster..heheh...
But does yours GLOW!!!
hehehe...
Works as a nice battery discharger too...if you leave it plugged in accidently....
might take a couple days....but you'll drain that battery eventually...hehehe..
Fly Hard!! Land soft...
CrazyHerb
hehehe...
CrazyHerb
My Feedback: (8)
Astro flight made one of those years ago, I only found out about it when a friend asked me to fix the slipping starter cone. When I took it apart to fix the sticky switch, I saw the good old mabuchi 540 motor inside the plastic case. The whole thing was the diameter of a v-8 juice can with a push button switch on one side. It had the cord to the power panel just like any other starter.
ORIGINAL: CrazyHerb
hehehe...
hehehe...
Well, anyway, I bought a sheet of styrofoam tonight -- if that Delta thing flies into me, it'll be your fault.
the "other" Andrew
TN
"Ya....that's cool....good idea....dustbuster..heheh...
hehehe... "
The horn button on mine is a bit of overkill since it cost around $5. I was in a hurry and didn't look around for anything cheaper. The doorbell button is a good idea. It is really a handy item to have.
...talk about discharging the battery... I learned not to try to run the the battery down by spinning a wheel with it. I burned the first motor out doing that.
hehehe... "
I'm going to slap another CheapDelta together as soon as I get a couple hours free....and try to do it lighter....HS-81's instead of standard servos...
and a 350 mah pack instead of full sized 600 mah....Maybe even cover it...with some moneykote...
You can't beat it with a stick.....
$60 - 2 channel single stick radio
$35 - Norvel .061
$1 - Worth of 3/4 in pink foam
$1 - Worth of packing and fiber tape
Elevon horns are popsicle stick cut in half (one for each elevon)....and glued into the foam...
Total cost - $97
Go back to the 1/2A main part...just posted PLANS for the little fireball....(make sure you disable your browsers AUTO-RESIZE function under tools/options)..
http://www.crazyherb.com/CheapDelta/cheapdelta.jpg
ENJOY!!
Weee haaa...
CrazyHerb
Cool, I just used a piece of metal from a hose clamp for my switch, seen at the following link.
http://www.northlandflyer.com/Tips__...r/starter.html
TN
ORIGINAL: planebuilder66
My Feedback: (8)
What I ended up doing for it was changing the thrust washers and bearings on the cone's back side and I drilled / tapped the cone for the set-screw, then I just ground a flat on the shaft to accept it. Put a dab of loc-tite on the 4-40 set screw and gave it back to him that day. I wish someone would make those again, it was the sweetest little starter I saw.
In a couple of threads I read that you want some on to make a 1/2a starter. What about the Sulivan 1/2a starter. Is it that bad or is it a well kept secert???
http://www2.towerhobbies.com/cgi-bin...?&I=LXCLY7&P=7
Dru.
Dru.
My Feedback: (8)
That is really similar, I will order one for my small engines. They work very well, and they can fit in small areas, taking up almost no room. Plus you don't have to hold a plane and a 5 lbs starter!, What I like most is the starting cone for the spinner. I'm going to be using it on the little gem I have now from HOB, the FW-190.
I made mine using a 540 motor and PVC tubing. The motor fits just right in an end cap. I drilled a holes in it for the shaft to go through as well as vent and mounting screw holes. I put on a short length the PVC tube with a small push button switch, more vent holes and put an end cap on it. You can make it long enough to put batteries in it or you could use wires to go your flight box panel. It's all in one smooth enclosed case.
Sorry no pics
ZZ
Sorry no pics
ZZ
TN
ORIGINAL: blvdbuzzard
Dru.
Dru.
