[quote ]ORIGINAL: Hemikiller I'm going to venture into the HV realm on my next plane and will start off using the 5495BH servos, 2S Lipo and an Optima series receiver, either a 6 or 7.
What is the best way to wire this for a glow powered plane?
A) 7.4V directly to the BAT/servo port
B) 7.4V -> regulator to X voltage - > BAT port
C) Pull SPC jumper and go 7.4V ->Y -> SPC & BAT
D)or? Thanks in advance! [/quote]
answered:
Optima Transceiver (RX) - Battery set up for Nitro/Gas models
following may also assist:
Optima Transceiver (RX) - Battery set up for Nitro/Gas models - caution re NiMH & Alert re LiFE.
Optima Transceiver (RX) - Dual or Multiple Batteries may be installed - Avoid
Brownout & Add Redundancy,
even one for each servo.
Alan T.
