KMS QUANTUM motors: -ARE THEY THE SAME AS AXI motors ...?
I have now found this information:
http://www.rcuniverse.com/forum/fb.asp?m=10021231 -Sept 2010
cobrajocky:
" ... The KMS Quantum 2820/05 was the exact same motor as the AXI Gold 2820/10 (KMS is a manufacturer in China), but apparently Global Hobby has dropped them to carry a really crappy line of their own ... Either way, there are no KMS motors in the US anymore ..."
I do not know how true it is,that KMS Quantum motors are the
EXACT SAME motors as AXI ... -I have never looked ...
Certainly, KMS Quantum motors are still available from many outlets in UK (in March 2013) -e.g.
http://www.sloughrc.com/default.asp?...:120-010,b:KMS
-even if they might not be available in the USA any more ...
Now:
Might KMS Quantum motors REALLY be the same as AXI motors ..?
After all,KMS Quantum motors are usually much less than half the price of a same-size AXI motor e.g.
http://www.electricwingman.com/brush...gold-line.aspx
Let us have a look: First, KMS Quantum 2820/05 vs AXI 2820/10 GOLD LINE
http://www.sloughrc.com/default.asp?...=M-KMSQ2820/05
http://www.modelmotors.cz/index.php?...e=10&line=GOLD
Also:
http://www.rcgroups.com/forums/showt...7#post19255401
KMS Quantum 2820/05: 142g; Kv 1130; Diam: 35mm Length: 48mm; LiPo: 3-4 cells
AXI 2820/10 GOLD LINE: 151g; Kv 1200; Diam: 35mm Length: 48mm; LiPo: 4 cells
-The specs of these 2 motors are certainly close to each other;a small Kv difference is easily within the range of measurement error; small difference in weight may be due to one motor weighed with connectors, the other without ...
***** And the 2 motors do look VERY very similar -indeed almost identical -on pics, see below ... *****
-And even the accessories for AXI and KMS Quantum motors look identical ...
Another comparison:
KMS Quantum 4120/05: 307g; Kv 710; diam: 50mm Length: 55.5mm; LiPo: 3-5 cells
AXI 4120/14 GOLD LINE: 320g; Kv 660; diam: 50mm Length: 55.5mm; LiPo: 4-5 cells
-Once again, specs are very close, Kv difference is easily within range of measurement error; one motor may have weight quoted with connectors, the other without connectors, etc ...
**** AND: THE 2 MOTORS DO LOOK ALMOST IDENTICAL (see pics below) ****
SO: WHAT ARE WE SEEING HERE ....?
ARE KMS QUANTUM MOTORS MADE IN THE SAME CHINESE OEM FACTORY AS AXI ??
(-Like the situation with: Hacker and Torque, Z-Hyperion; LiPolice, OK Hobby Infinite, Shulman Aviation FURY, Gens Ace, motors etc etc)
OR: ARE KMS QUANTUM MOTORS JUST COPIES (i.e. CLONES) OF AXI MOTORS, MADE IN A QUITE DIFFERENT FACTORY ... ?
-Llke PULSO motors are just copies of AXI,-but (evidently) made in a completely different factory ...?
If indeed, KMS Quantum motors are made in the same OEM factory as AXI motors, and they turn out to be identical with AXI motors (apart from a different external colour and brand label)
-then we will have the situation that KMS Quantum motors are basically AXI motors for ~40% of the price of AXI ...
pics show: 1, 2, 3: AXI 2820/10 and 2 pics of KMS Quantum 2820/05
4, 5, 6: AXI 4120/14 and 2 pics of KMS Quantum 4120/05
7: AXI 4120/10, from rear aspect -showing that the AXI and KMS accessories (in pic 5) even look identical
