there are several decent threads on the build here is one
http://www.rcuniverse.com/forum/m_48...tm.htm#4868696 but a little search time and you might be able to pick up some helpful tips on your build so far it looks clean.
TF kits build easy just follow the instructions(I use a yellow highlighter to check the boxes as I move along) and its a good idea to read ahead and familiarize your self with the steps you will be doing before hand other wise keep posting you will find most questions are answered fairly quickly around here
I used the CJM retracts for mine glassed with water based poly and painted with warbirdcolors paints, I used
www.getstencils.com stencils for the emblems
