Mix 3 is the correct mix to use. Why do you want to use Mix2? At any rate, in Mix2 simply set flap as master and elev as slave.Make sure to change from INH (Inhibited).
I need more info to understand what is not working the way you want and what you want to do and how you want it to work.
