RCU Forums - View Single Post - 18MZ variometer melody range, offset and deadband setting resolution
Old 08-06-2018 | 07:30 AM
FUTABA-RC's Avatar
FUTABA-RC
In the SYSTEM TYPE menu when linking the RX you can set the D/L (down link) or sampling rate in 0.1 millisecond intervals. Even using the 0.1 ms setting there is still going to be a lag in the vario. Even full scale varios have a slight lag and you need to work to not end up chasing the vario.
As far as I know you cannot alter the resolution of the setting in the vario itself. The range that is available is all you get.
