Originally Posted by
rcwarbirdman
Appreciate any help you can provide. I know that both transmitters take an SD card, so I'm hoping this will be the easy way to transfer things over.
I am nearly certain you cannot simply copy from the 12FG to the 12K using the SD card. I have also confirmed there is currently no converter available, so as I suspected you will need to do it manually. Goes pretty quick once you get it down.
Create Model
Set wing type, etc.
Set up functions
Set end points
Set subtrim
Then set all your mixes, etc. as they were in the 12FG.
