Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
Reload this Page >
Fliton Quiet Storm build
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 01-17-2005, 04:34 PM
awat65
My Feedback: (17)
Default Fliton Quiet Storm build
I just received my Fliton USA Quiet Storm and will start a build thread.
Motor: Hacker 20-20L outrunner
Speed controller: Hacker Jeti master 30
Batteries: Thunder Power 2100
Servos: Hitec HS55
Old 01-17-2005, 08:24 PM
MX240
MX240's Avatar
Default RE: Fliton Quite Storm build
That sounds good,
I have been looking at this airplane.
I looked at their web-site today and can't find a price...?
Let us know what you think.
Old 01-17-2005, 10:35 PM
awat65
My Feedback: (17)
So far I have been taking pictures of the build. I have the tail feathers on and landing gear. I must figure out how to post pictures of my build. Price is $164 at Cheif aircraft.
Tony Watkins
Old 01-17-2005, 10:58 PM
awat65
My Feedback: (17)
Default RE: Fliton Quiet Storm build
How do I post pictures anyone?.
Old 01-18-2005, 07:30 AM
swk551
Here are some build pictures of the Quiet Storm.
The first picture shows I substituted 0.070" CF rod for the rudder and elevator push rods. The music wire supplied is to weak and deflects with max servo movement. I use thread and CA to attach the CF rod to the music wite ends.
The second picture shows I substituted a 3/8" maple motor mount stick for the balsa one. I used the supplied Hacker mount and made a front attachment flange for the 3/8" stick.
Picture #3 shows the Falcon 2500ma 3S1p battery location. I use a CG right over the main spar (approx 90mm from the wing LE).
Picture shows the plane almost ready to fly. I drilled a hole in the middle of the main spar to install a thread loop. I use the thread loop to check CG after I install the battery. Depending on flying 3d or pattern, I can now easly check CG adjustments at the field.
By the way, this plane flys great. I had my first flight with 15mph winds and gusts of 20mph. No problems on the flight. I did break out the landing gear plate on landing on grass. Later I will post the mods I did for the landing gear plate reinforcement. I was lucky and had no damage to the plane.
I am using the HiMax 2025-4266 motor/gear, APC 12-6sf prop, CC p-25 ESC, Falcon 3s1p 2500ma LiPo. Final weight with landing gear plate mods was 27oz. My static thrust is between 38 and 40oz. No performance problems.
Steve
ID:	216906   Click image for larger version
ID:	216907   Click image for larger version
ID:	216908   Click image for larger version
Old 01-18-2005, 12:09 PM
awat65
My Feedback: (17)
Steve how did you post your pictures as well?.
Tony
Old 01-18-2005, 01:35 PM
swk551
After you go to post reply, there is the reply box you type in your message. At the bottom of the frame is a "Click here to upload!"
Just click on it and go to the brouse box and upload a picture from your files. There is size limit on the pictures. All of my pictures are taken at 1mb or at the VGA resolution.
Good luck,
Steve
Old 01-18-2005, 07:24 PM
Shortman
My Feedback: (21)
Shortman's Avatar
Here is for the visual learner[8D]
ID:	217189   Click image for larger version
ID:	217190   Click image for larger version
ID:	217191   Click image for larger version
Old 01-18-2005, 07:27 PM
Shortman
My Feedback: (21)
Shortman's Avatar
Also save the files as JPEG's. Otherwise even the tiniest bmp will be to large to post here. If you have to big of a file, open Paint and go to tools, strech/scew and edit it to like 75 or 50% vertical and horiztonal, or you can email them to me at [email protected]
Old 01-18-2005, 10:22 PM
awat65
My Feedback: (17)
In this picture, I removed the aileron from the wing and removed the hinges. I drew a center line on the hinges and re-inserted them into the aileron and put the aileron back on to the wing with the ca hinges. The centerline I drew on the Ca hinges were to make sure the hinges were centered, half the hinge in the wing and the other half in the aileron.
Old 01-18-2005, 10:55 PM
awat65
My Feedback: (17)
Thanks SWK551 and Shortman for the help. I got it figured out and am posting pics with my build.
Tony Watkins
Old 01-19-2005, 01:32 PM
awat65
My Feedback: (17)
This pic shows how I marked the center of the hinge.
Old 01-19-2005, 01:47 PM
awat65
My Feedback: (17)
This pic I cut the slots out on the side for the horizontal stab and wings. Next I fitted the horizontal stab in the fuse and drew the cut lines to remove the covering so as to have a wood surface to glue the stab to the fuse. Next I centered the stab on the fuse. I then slid the stab out a little and applied epoxy and did the same the opposite direction. I used 15 min epoxy so I would have time to align the stab to the fuse. Once that was dry I attached the elevators the same way I did the ailerons. Make sure the stab is centered and aligned
Old 01-21-2005, 10:23 PM
awat65
My Feedback: (17)
This pic shows the alignment
Old 02-02-2005, 01:26 AM
awat65
My Feedback: (17)
Well I am still building the Storm. I changed my mind on the servos and will be using Futaba S3108. I will be modifying the motor mount to accept the Hacker out runner motor. I mounted the gear and wheel pants. I modifyed the wheel pants so I could remove them with out taking the wheels off. I will be post more pics today.
Old 02-04-2005, 12:13 AM
awat65
My Feedback: (17)
In this pic you can see how I cut a slot in the wheel pant to slip over the wheel. At the top of the slot is were the screw goes to hold the wheel pant to the gear.
Old 02-04-2005, 12:23 AM
awat65
My Feedback: (17)
More pics
Old 02-10-2005, 03:56 AM
FlitonUSA
Great information Tony, can't wait to see the rest of this build thread.
- Edson
Old 02-14-2005, 01:08 AM
awat65
My Feedback: (17)
I now have all the servos installed and getting ready to install the motor. I will post pics later today.
Old 02-16-2005, 04:32 AM
snap_roll
hey, swk,where did u get that gearbox? wads the diameter of ur motor shaft?
Old 03-03-2005, 03:20 AM
.:RClunatic:.
My Feedback: (21)
hows it coming along?
Old 03-03-2005, 03:46 AM
awat65
My Feedback: (17)
Sorry I have not posted pics as of yet but will do so today. I have was not feeling to well last week but I am feeling better now.
Old 03-03-2005, 08:46 PM
awat65
My Feedback: (17)
I have finished the plane since this picture. I re-inforced the motor box with the hacker outrunner on it. I was going for a test flight today but it was to windy. I will try for a test flight this weekend and get some video of it. I will be posting more pics of my build as well.
Old 03-07-2005, 10:52 PM
Ryguy
You flown it yet?
Old 03-18-2005, 10:15 AM
Randog_2
Thank you AWAT65. Looking forward to seeing your flight video.
