Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
 GP Matt Chapman Flat out >
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 12-14-2005 | 09:50 AM
Default GP Matt Chapman Flat out
I'm thinking of getting the GP Matt Chapman Flat out. This will be my first 3D model. I'm fairly experienced but wanted to get feedback on any of the flat out models.
I wanted to get something that looked good, was inexpensive and I could fly in my front yard, also the idea of learning 3D at a low speed was a plus (and the videos you can download of these types of models are just so cool!)
I'm also thingin of upgrading to the brushless motor.
Old 12-14-2005 | 10:03 AM
Default RE: GP Matt Chapman Flat out
I had the Flatana and liked it alot. I would deffinately upgrade to the brushless setup. The Flatouts have a great hinging system that allows incredible throw and in minor mishaps, the control surfaces will pop off preventing damage.
Go for it, I think you'll enjoy it.
Old 12-14-2005 | 10:14 AM
i had three of these!! it was a great flying plane!!! but you have to do a few reinforcing things to make it strong. on the ailrons use some flat carbon thru the control horns to make the foam stronger there also take some thread and wrap around the control horn and the carbon tube that they hinge off of, cause they conrol horn is also a hinge and it like to pop off and it knocks it bad out of trim!!! i also ran some thin cabon onside the trailing edge carbon to add some strengh to the wings cause on the cap they flex some cause it's a low wing plane!!!! one thing i did to the landing gear legs was i add an extra peice of 1.5mm carbon to th leg to make it stronger, cause they are kind of weak, and becarefull and don't have any hard landings cause the legs will break off. i used a rimfire!!! an excelent motor for the flatout!!!! it has tons of power!!!!! and his plane it did fly like a cap!!! i couldn't beleive that a flat foam cap would like just like a cap but it does!!! all in all it's a very enjoyable plane to fly!!! i loved to do slow fly bys and roll to knife edges to do picture passes!!!! i've seen matt chapman fly the real cap580 at joe nall and it is one awesome show!!!!!
mike
Old 12-18-2005 | 01:56 PM
I have the turmoil flatout and I really like it. I put a custom cdr brushless kit on the plane and it has plenty of power to 3D and go vertical. I'm using three hs-55 servos, thunder power 730 3 cell, phx 10, and an 8x4 gws direct drive propeller. I love the plane.
Bevo
