Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
 Anyone have experience with MS COMPOSIT epp planes? >
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 02-13-2007 | 09:30 PM
Default Anyone have experience with MS COMPOSIT epp planes?
Hello all! I bought one of these at E-FEST, and had a couple questions regarding set-up and performance. I'm hoping to use the plane as an aerobatic trainer mainly. On this web site[link]http://www.mscompositusa.com/unique---red-white-epp.html[/link], the recommended battery is smaller than what the instructions call for. Instructions say 1250 to 1500mah. Also I don't have any idea who makes EM 300-34 motor they recommend, or what would compare to it. I have a Rimfire 22M-1000 laying around. Is it comparable? Those are my two basic questions, but if anyone can comment on the durability or performance of this plane, I would be most grateful. Thanks in advance!
Trevor
Old 02-13-2007 | 11:33 PM
Default RE: Anyone have experience with MS COMPOSIT epp planes?
if the flying weight is 12 ounces the rimfire with a 9x3.5 or whatever is common with those would work fine for aerobatics. i'd probably shoot under a 1000 mah for weight with an 8 or 10 amp esc
Old 02-15-2007 | 03:52 PM
Trevor,
My Blade Dancer was there but since I didn't have a Spektrum receiver for it I was only able to get one flight with the 72mHz. This airplane flys great with the E-flite 400 outrunner which is probably more power than necessary. I haven't tried the 370 yet. Also am using 11/3.8 prop indoors. All up weight with 1320 batt was 12.5 oz (incl landing gear).
I did cut a bit of the elevator away to allow additional rudder throw as it seemed a little weak in knife edge manuevers. It is great fun and has survived a couple un-intended landings with out a mark on it. Love that EPP when done right (cut not molded!)
I think this will make a great small field outdoor model when the weather is a bit warmer!
Oh, one thing about the epp, you can cut a knife slot in the foam then pushe the servo wires in and the foam heals over it so there are no visible wires! works really cool.
Jimnie
Old 02-15-2007 | 04:52 PM
Thank you both for your replies! I do intend to use my Rimfire, and probably a 910 lipo to start with and see what happens. Jimnie, thats an awesome tip on the stashing of servo wires! So far I've only had Depron foamies, and they were/are all GP Flatouts. With all the negative posts I've read, and my own experience with them, I'm ready to try a different material. The flatouts are just too fragile for a 3D newbie such as myself IMHO. Probably won't put her together for a couple of weeks( Just got a foot of snow), but I'll try to remember to let ya know how it all works out. Thanks again!
Trevor
Old 02-15-2007 | 07:31 PM
EPP is really remarkable material if not a little heavy. have you thought about the yak55 at hobby lobby? You mentioned you had the flatout flat foamies... the yak 55 gets much better reviews
Old 02-16-2007 | 09:15 AM
I believe I have seen the Yak at Hooby Lobby. Matybe I'll do a little research, and see about picking one up to try out. Thanks for the suggestion!
Trevor
Old 02-17-2007 | 04:24 PM
I've been playing with the HL Yak... good fun. Running a Rimfire 22m-1000, 8a controller, and a 1320 mha ThunderPower.
It flys good for me (newb) and the battery lasts forever.
A note on snow... it cushions the hits!
Old 02-17-2007 | 08:03 PM
I just put another yak together tonite... can't say enough about the fast building. I think it took all of 40 minutes
they've also just gone on sale today for 20 bucks...
I think i'll try one of these epp's next... looks like a real softball for ground hits
Old 02-19-2007 | 07:11 PM
hello, I also have just bought a blade dancer by ms composit at e-fest, but I didn't get home with the instructions. If some one will help me out, I would be very greatful. If you could scan it and put it on here, so I could print it off.....thanks again onestick900..
Old 02-26-2007 | 01:27 AM
we just finished putting together a "unique"
Used an axi 2208/26, 9x3.8 prop, thunderbird 18 esc. Apogee 830 (3cell)
This is one sweet flyin little plane!
Flew it right behind my airfloilz edge and I really enjoyed them both[8D]
now if we could just get some warm weather[sm=drowning.gif]
