 what servos for 3d >
what servos for 3d
what servos for 3d
Old 03-19-2012 | 12:22 PM
Default what servos for 3d
im flying a msx-r 26% with a dle 30cc on it and i have a 4.8v 1500mah nimh battery i use futaba rx/tx i want to know what kinda servos should go into it i dont want to spend $500 on hitech 7955 what about jr sport st126mg? i know they need to be MG what about torgue? please help
Old 03-19-2012 | 12:42 PM
BarracudaHockey's Avatar
Default RE: what servos for 3d
For a 30CC 5625's should be more than adaquate
Check Chief Aircraft they usually have package deals with good prices.
Old 03-19-2012 | 01:00 PM
not a bad do you know anything about the jr sport 126mg i would to buy a servo that isnt strong enough to let me do what i plan
Old 03-19-2012 | 01:54 PM
analong power HD's troby built has them
Old 03-19-2012 | 05:32 PM
KWJ48's Avatar
If you want to get a little more out of any servo you choose, switch that battery out and go to 6 volt.
Old 03-19-2012 | 05:50 PM
i read tho that on some servos they can get jitter when you run 6v im going back and fourth between jr sport st126mg or hypenion 20umd they are both about 130oz/in torque and about .19 speed
Old 03-19-2012 | 06:09 PM
http://www.troybuiltmodels.com/items/HD-8309TG.html
check them out srsly though power HD sevros might suprize you dont get cought up in hype and ask around
budget is also HS 985'S
Old 03-19-2012 | 06:16 PM
HD-9150MG seem's to be the most liked POWER HD servro
just do yourself a favor and put it in your google toolbar serach and read other forum's results
Old 03-19-2012 | 06:56 PM
yea i just looked at them wow they look great for $14 whats the catch? and do you have to buy the mpi arms or is that like a upgrade?
Old 03-19-2012 | 06:58 PM
http://www.troybuiltmodels.com/items/HD-1501MG.html
what about these?
Old 03-20-2012 | 08:02 AM
daveopam's Avatar
My Feedback: (9)
I sound like a broken record with these, but the Futaba 3305 is a great bang for the buck. Metal gears, love 6 volt, and less than $40 each. For a bang around 3D plane these are great.
david
Old 03-20-2012 | 09:14 AM
Yea I couldn't remember those, I was going to look on Futaba's site.
Old 03-20-2012 | 09:54 AM
wyo69cowboy's Avatar
I've been happy with the Hitec 5625's; been using 6 of them in my 50cc Reactor now for almost 100 flights. Here's a good place to get them: [link=http://www.toddsmodels.com/category_s/264.htm]Todd's Models[/link]
Old 03-21-2012 | 08:22 AM
DenverJayhawk's Avatar
i've been using HS985mgs on my 71 slick and 74 Edge. Very happy with them. Plus i'm not skilled enough to really notice the difference in digitals.
Curious about the Futaba 3305s. is that enough torque at 124oz@6v for a 30cc bird?
Old 03-21-2012 | 11:53 AM
DiscoWings's Avatar
My Feedback: (76)
Hs-7955
Old 03-21-2012 | 01:32 PM
daveopam's Avatar
My Feedback: (9)
For hard core 3D the 3305 might be marginal on the rudder. To run an Aile or half an ELEV, you wont have any trouble. IMHO This is assuming the man that set up the linkage gets the geometry right. I've seen some with the pushrod nearly on the surface to get more throw. No servo is going to overcome that.
David
Old 03-22-2012 | 04:48 AM
Rocketman_'s Avatar
Several years ago my choices for cheap servos from reputable manufacturers were the Futaba S3305 MG and the JR Sport ST125mg (predecessor to the ST126). When I need more servos I will again buy the S3305 or the ST126mg.
I use them with Li-ion batteries regulated to 6 volts in 3D models powered by OS 1.60FX glow 2-stroke and 26cc to 36cc gas 2-stroke engines. My largest 3D planes have a 76-inch wing span and can do knife edge loops with one S3305 servo on rudder.
Don't need no stinkin' $100 servos or juice suckin' buzzing digital servos.
Old 03-23-2012 | 05:06 PM
My Feedback: (12)
For their price point, I find the Hitec 985's are the best. They can be had for about $65. Although the 5645 and 5625 are about $15 dollers less they are not in the same league performance wise. The Futaba 3305 and 3310 servos are garbage.
Old 04-01-2012 | 12:57 AM
Rotten40851's Avatar
Anyone using the SpektrumA6030's? Digital,Titanium gears, 278 oz tq@ 6 Volts, dual BB, coreless motor. aluminum heat sink case?76 buckseach @ my LHS
Old 04-02-2012 | 06:37 AM
I bought a pair for my 100cc H9 Extra rudder; only put about a dozen flights on it before selling it, but they were very smooth and nice. These servos are made by Savox for Spektrum; they have a very good reputation so far.
Old 04-03-2012 | 07:24 AM
daveopam's Avatar
My Feedback: (9)
You may not like my choice of servos. To each his own. But don't call them garbage. I have hundreds of flights on 3305s in 3 different planes. In all that time I have had one go bad that would not hold center, and one that lost it's gears. (my fault not the servos) So make all the suggestions you want, and let each reader decide for themselves which opinion they would like to follow.
Thanks, david
Old 04-03-2012 | 09:00 PM
FWIW, I witnessed a Hitec 5485 fail spectacularly today [X(] Flying with a friend; he thought he had an issue, so he landed, and we checked things over, doing a range check as well. He went up again, flew for a while, and said something's not right, and landed. Upon landing, one elevator servo was not working(hence the weird behaviour in the air). As he was checking it over on the bench, servo went hard over then smoked up! Literally was smokingyikes! Running on a LiFe pack; don't know why it failed, but glad it was on the ground, not in the air, and while he was there to unplug the power...
Old 04-16-2012 | 07:46 AM
New to the world of 30cc size aircraft.   I bought an 71" slick
Plane runs great and came with some Power HD 1501mg servo's.  The rudder wasnt' working so I ordered a Hitec hs-985 to replace it.  It has become clear as day how much better this hitec servo is over the HD's.  The speed and precision of the Hitec crushes the HD's..
so I want to replace the rest of the HD servo's on the ailerons and rudder.
How do the hitec HS 5625's compare to the 985's?   I see the 5625's are about half the price... 35ish vs 65 ish a servo... I'm not hardcore 3D... but I do want it to perform.     thoughts?
Old 04-16-2012 | 06:39 PM
Troy Built Models has 985MGs for $57. By far the cheapest that I've found. I'm using them in my 71 slick and 74 Edge. Do yourself a favor and just use 985s if you can afford them. Don't go cheap with the 5625s.
For these 30cc models, I've found you can go cheap on other parts like batteries, servo wires, motors, ECSs, props (APC),etc. But the one thing I've found where the higher price really is justified is a good servo. It makes ALL the difference. Kind of like the speakers on a stereo system. You can have a bunch of crap in terms of the amp, MP3 player, etc, but use good speakers because that is what you'll notice.
PS....you'll love the slick on 985s. A lot of guys also like the Savox TG and its Align Equivalent. I'm not talented enough of a 3D flier to notice the difference in speed and I think the 985s are already blazingly fast when you tap the sticks.
