Capiche 140 EX and IC version
#2451
Not really, both 140 and 160 very solid on idle. Once you get above 1/2 throttle the 160 is noticeably more vibration free over 140DZ and it sounds softer.
Angus
Angus
#2452
I've been on a bit of a lunchtime outing today....
After looking through all 10 sheets of 1/16 in my LHS, I thought i'd pop and see what SLEC had in stock...
After weighing what seemed like nearly 4000 6" sheets, I found some that weigh as low as 22 g per sheet!
The weight range is amazing, as I found some sheets that weighed 40 g
Anyways, the upshot is I now have all I need to finish the model! and am covered in Balsa dust!
What a great chap Ian at SLEC is, letting me loose on his Balsa store!!
Regards,
Steve
Regards,
Steve
#2453
Oh No! One wing turned out 3mm longer than the other!!!
Revisiting the plan confirmed that the error is on paper!
Luckily, I had not trimmed the bottom sheet when I noticed this, and managed to move the tip rib out another 3mm!
Some of the outboard ribs are now out by a couple of mm cos of this.
Is this why we build both wings to stage 1??
Was this a photocopy inaccuracy, or a CNC error?? I'm guessing a phototcopy error??!
No biggie, and sorted now, just a FYI
Regards,
Steve
Regards,
Steve
#2456
Its actually so that you know which wing is which..... wouldnt want to put them on upside down by accident !
Of course colour scheme can help give a clue too in this respect.
It also help knife edge spins when the longer wing upper most
#2462
That's Cabin fever setting in...... Been windy for far too long now......[&o][&o][&o]
I now have 2 matching length wings, one is webbed and ready to sheet... Other not far behind....
Getting there slowly.....
Regards,
Steve
Regards,
Steve
#2469
Nope im Xy chromosome. No more, no less. Def no Japanese either. Im 100% prime Scottish Beef.
Aye the pink is a good colour. Very good for orientation in bad light or grey days. You guys should try it, might enable you to fly a straight line
Angus
[>:]Angus
#2472
Don't the Scottish wear skirts too???
Straight lines???? You need one of them thar samey looking F3a pattern ships like a synergisd emerald or summat like that...
But the pics of them are a great reminder as to why I bought a Capiche in the first place!!
Regards,
Steve
Regards,
Steve
#2474
Because what do you fly between manouvers, oh yeah straight lines
ORIGINAL: Berk
Regards,
Steve
Regards,
Steve
#2475
The "skirts" you refer to are kilts. Only men can wear them.
You dont need an F3A plane to fly a straight line. Ive won an F3A contest with a Capiche. It just requires a bit of skill
So you picked a Capiche over an out and out F3A model, good for you. So did i as i happens last time i got a model and i really, really enjoy flying it. Does'nt compare to a well trimmed pattern model though as those of you who have flown one will know. I liken it to a Bigfoot and a Ferrari. They're both excellent fun. You can do more with a Bigfoot, go over cars etc but for pure driving pleasure, finesse and accuracy you have to go with the Ferrari. Same with the Synergy and Capiche. Better still do what i did and get both
Angus
Angus
