Minimum Power to Weight?
WA
Never flown a 3D plane before, and I know you need greater than 1:1 ratio, but what would you guys say is the minimum ratio for doing any kind of vertical?
Patriot
Patriot
what are you classifying as power ? what units ?
maybe thrust to weight ? ie 1.5:1 would give you a decent pull out from a hover ?
but how do you measure thrust of an engine/prop combination without building a proper thrust rig.
Maybe a better answer is enough thrust to pull out of a hover with plenty of authority, this will also be enough for other 3D stuff like waterfalls.
My Feedback: (24)
all my planes hover 1 to 1 between 1/4 and 1/2 throttle. which leaves lots of explosive power in reserve to pull out when necessary. I am scared like hell when I fly someone elses airplane that hovers at 3/4+ throttle setting. hopes this helps, be careful not to add unecessary weight with a bigger engine - see my thread (increase power and decrease weight) on this list. good luck, hope this helps. ray
