Reload this Page >
AeroWorks Edge 540T 46-60?
Old 10-21-2011, 11:52 PM
  #1801
Tumalik
Tumalik's Avatar
Default RE: AeroWorks Edge 540T 46-60?
Maiden Success!!!!
At 2 3/4 and 3 inch my CG was super tail heavy, so decided to move my battery from side of throttle servo to under fuel tank. After the batt move, CG was still tail heavy at 2 3/4 but nose heavy on 3 inch.... HHHuuuhhh???? could not get a steady cg. Took the decision to take off.
11 clicks of up elevator and 4 clicks of right aileron. Smooth as i imagined... A bit twitchy to my liking but gave her a touch of more expo. Lands like a trainer(though a bit hot) and had the first dead stick after 14 minutes of buzzing around, once again.... give her a good dive and she'll come right in for landing.... THANK YOU GUYS FOR THE SUPPORT! i know i have been a bit clingy on the questions, though it has worked for the best. BTW after 26 mins of flying my 2200 mah 2S(7.4v) at a full charge of  4.19 v/cell  was left with 4.10v/cell .  Now i hear alot about big drops once lipos pass 4v, assuming 3.7 v is the red line..  should i fly a third or fourth flight??? or would i be pushing it?
Old 10-22-2011, 09:11 AM
  #1802
albsurfer
Tumalik,
Don't go under 3.7v on your lipo pack cells. Glad to hear everything went well. Keep on flying.
Old 11-28-2011, 02:52 PM
  #1803
phatg0nk
I know you want a more solid answer, but i have lost 2-3 planes in my life from going for 1 last flight.. I think it hurts nothing to be safe and fly another day..So i definatly wouldnt do it till you have solid confirmation..
Old 11-28-2011, 11:26 PM
  #1804
Tumalik
Tumalik's Avatar
Thanks guys..
Old 03-04-2012, 04:46 PM
  #1805
phatg0nk
I think the last time i posted here was saying i lossed mine over a bluff..
I since purchased an Extreme Flight 50cc yak -dle 55-7955tg's and some A123 batteries..Its already to go now except the installation of the engine.
Im very much looking for ward to it, but I am also looking Forward to getting another AW edge" I really Miss Mine"
Plus need to get my fingers moving a bit again on the plane i loved for a couple years, before diving into my first gasser!
This time i think ill go with balljoints all arround a little better servos and a bit more radio mixing that i have become more and more familiar with over this last year..
I think im going to like my replacement Awedge more than my first)
Probally gonna go saito .91 -I had magnum .91 first time, and now i have a saito lying arround in a splintered big stick..But i dont think any engine dmg was done.
Old 03-04-2012, 05:05 PM
  #1806
clytle374
ORIGINAL: phatg0nk
Im very much looking for ward to it, but I am also looking Forward to getting another AW edge'' I really Miss Mine''
Good to see some activity here. I was actually working on mine when it got the notification. I was changing the gears in the Hitec hs-5645 to gears for the hs-5625 to get a bit more speed. The bearings for the servos I ordered weren't needed as the old ones came out easily and are not as high of quality as the Hitec bearings. Plus some computer involved with getting the parts must be hacked since my debit card started developing charges from places I've never been. I'm starting to think I'll put it back the way it was
Cory
Old 03-04-2012, 05:13 PM
  #1807
phatg0nk
I have yet to get into a servo, sounds fun though)
Old 03-04-2012, 06:34 PM
  #1808
albsurfer
It depends on the servo. In some, the gear setup is terrible to put together.
Old 03-05-2012, 04:37 PM
  #1809
phatg0nk
Yeah i hear yah..I just love getting into stuff)
Oddly enough i have never been in a servo. guess i never had any reason to, because i was always using 10 dollar servos..
Mostly the High torq Mg digital servo from china for 10 DOLLA. Actually other than 1 nice highspeed servo i had in my edges throttle ive never owned an expensive servo until now.And its to put in my 50cc..
I think like i said before though, this time arround on my replacement edge! " Since mine flew away and didnt come back" Im not gonna skimp on servos so much..See how much i like the results.I believe as my skills have improved much recently I will notice the difference much more than i might would have back then.Just because of the more aggressive flying style..
Actually i noticed at http://www.rcaircraftcomponents.com/
They have hitec 7955's for like 30 dollars less than most places, and i havnt priced Savox servos else where but they seem to be a bit cheaper than the hitecs and i have read some nice things about them.
Any experience with Savox servos? And if so mayb a suggestion on a which exacts? would be nice for the edge keeping price down as much as possible But yet not trying to skimp- yah know!
Im sure theres a point where <diminishing returns> kick in- Compared to what you spend/need for this size plane.
Old 03-07-2012, 04:08 PM
  #1810
Tumalik
Tumalik's Avatar
go for savox. great feed back on them and great specs too. they seem to be one of the few who made servos for spektrum (a6030) and cover the "in between power / speed market' that hitec and jr won't.
good luck!
Old 03-07-2012, 09:21 PM
  #1811
albsurfer
I'm using a pair of 49 oz/in small servos on the rudder & elevator of my 3hds 47" extra 300shp. I haven't had any problems. I used the recommended HITECs and in a 12 mph gust, the rudder servo stripped when it hit the ground and the elevator servo failed in-flight causing the crash. The two SAVOX I have now are larger then the recommended, but they've taken 12-13 mph gusts 6 times now without a failure! The HITECS that failed were HS-65MG servos and I've lost 5 of them now, 3 without a rough landing or hitting the ground.
I just lost a new HS-311 used for a throttle on a .46 size plane on the maiden flight! So... guess who's thinking of not using so many HITEC servos now.
If I go for something really large, I would seriously look at SAVOX. I'm considering them right now for a .90 project I'm thinking of purchasing.
Good luck.
Old 03-08-2012, 02:59 PM
  #1812
phatg0nk
ty guys for the input
Old 03-08-2012, 05:52 PM
  #1813
N1EDM
I'm not familiar with Savox servos... can someone give me a link?
Bob
Old 03-08-2012, 07:24 PM
  #1814
phatg0nk
I was very pleased with the prices at http://www.rcaircraftcomponents.com/
Old 03-09-2012, 06:09 PM
  #1815
N1EDM
Hmmm, those are a bit pricey for me. I have Futaba S3152's in mine and they work beautifully for me... Let us know how your Savox servos work.
Bob
Old 03-09-2012, 07:20 PM
  #1816
phatg0nk
Yeah most im sure are overkill in torq, And being coreless and Tg - thats more of a gasser stop really at valleyview..but cant beet the prices, my hitecs were 30-40 cheaper per servo there. they may have lower line savox servos out there that would be realy price friendly and a great servo.."So they say"
Old 03-23-2012, 01:18 PM
  #1817
AreoFanatic
I have an O.S. .55 AX in mine spinning an 11x7 which gives it plenty of speed but not enough torque for vertical. I initially tried a 12x8 and it was so slow it barely got off the ground. What do you suggest i use if i cant get a Saito 100 soon?
Old 03-23-2012, 02:18 PM
  #1818
phatg0nk
I flew it on a magnum .91 - was cheap - dependable and alot of fun. A matter of fact after initial tuning i didnt touch the needles for 2 years and it started first flip after choking every time..Power was a little so so to me at first on a 14x6 then i went to a 16x4w and it actually became a little faster and a hell of alot more pull and vertical power.Was hovering and harriers were pretty stable with this.. Then i switched the vess 15 x6 wood prop and increased speed quite a bit , lost a hair bit of pull but not much really and spooled up alot better than the 16x4w did.Over all the magnum with the Vess prop was a blast..I also did a xoar wood prop, didnt have near the pull but got pretty quick for my taste on the edge
If i had it all to do over again, And i do considering i just ordered a new airframe)
I think i will go with the saito 100 as well conisdering i think it weighs no more than my magnum 91 - mayb less!
But if money doesnt allow me and i wouldnt hesitate to order another magnum 91 for this it may even be very well whats going to happen , Ive been throwing alot of money into a a gasser plane
Old 03-23-2012, 03:08 PM
  #1819
AreoFanatic
so it would be more worth it to wait a while and save for a Saito 100 i guess thats what ill do...until then what do you suggest i use on my O.S. .55?
Old 03-23-2012, 07:20 PM
  #1820
phatg0nk
honestly i never used a 2 stroke on this airframe , im sure some one here has though)
I wanted to ask if any one has had a good outcome with a gas engine on this frame>?
Old 03-24-2012, 06:31 PM
  #1821
jknox
Originally built mine with a 65AX which was just adequate with the right prop. Have since re-engined with a Saito 82. Better sound, better vertical, but still not quite there. Saito 100 would be the ticket with this frame in my opinion.
Old 03-25-2012, 03:10 AM
  #1822
airborne2.4
ORIGINAL: jknox
Saito 100 would be the ticket with this frame.....
Or maybe the OS FS-95V.
http://www.osengines.com/engines/osmg0900.html
http://www.youtube.com/watch?v=CBEZbIFMeuk
Old 03-25-2012, 05:52 AM
  #1823
jknox
Agreed, and the price is right - the new95could well be my first OS 4-stroke
Old 03-25-2012, 09:51 AM
  #1824
N1EDM
I've been running mine with a OS-91 2S and a 3-blade prop. I think I might be running out of vertical, but by then the plane is too far up to tell clearly...
Bob
Old 03-26-2012, 12:55 PM
  #1825
clytle374
Not sure what's going on with rcuniverse, but I quit getting email sabout this thread getting replies.
Update on changing the servo gears: It was easy and the bearings came right off. The increased speed was worth it too, it hovers very nice now.
Cory
EDIT: Looking at the OS 95V, I think I'd stay with the Saito being that it is lighter, very well proven, and more powerful than the OS. I also don't like the gear train in the OS 4-strokes. I know it may work fine, but such gears are to be avoided IMO. Now the tappets don't even run in line with the pushrods. I understand that for OS'es other engines it was worth the complex gears and putting endloads on the camshaft to neatly line everything up, but this seems like an ugly design to me.
